PickfirstSelectionSet 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 826| 评论: 0|原作者: admin|来自: AutoCAD
获取 pickfirst 选择集。
object.PickfirstSelectionSet
类别: 文档
此属性应用于的对象。
只读:是的
类型:SelectionSet
pickfirst 选择集。
Sub Example_PickfirstSelectionSet()
    ' This example lists all the objects in the pickfirst selection set.
    ' Before running this example, create some objects in the active
    ' drawing and select those objects. The objects currently selected
    ' in the active drawing will be returned in the pickfirst selection set.
    Dim pfSS As AcadSelectionSet
    Dim ssobject As AcadEntity
    Dim msg As String
    msg = ""
    Set pfSS = ThisDrawing.PickfirstSelectionSet
    For Each ssobject In pfSS
        msg = msg & vbCrLf & ssobject.ObjectName
    Next ssobject
    MsgBox "The Pickfirst selection set contains: " & msg
(defun c:Example_PickfirstSelectionSet()
    ;; This example lists all the objects in the pickfirst selection set.
    ;; Before running this example, create some objects in the active
    ;; drawing and select those objects. The objects currently selected
    ;; in the active drawing will be returned in the pickfirst selection set.
    (setq msg ""
          pfSS (vla-get-PickfirstSelectionSet doc))
    (vlax-for ssobject pfSS
        (setq msg (strcat msg "\n" (vla-get-ObjectName ssobject)))
    (alert (strcat "The Pickfirst selection set contains: " msg))
GMT+8, 2026-11-20 18:00
