PickDrag 属性 (ActiveX)
控制绘制选择窗口的方法。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。False 注意:此属性的值存储在 PICKDRAG 系统变量中。
例子VBA: Sub Example_PickDrag()
' This example reads and modifies the preference value that controls
' the method of drawing a selection window.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesSelection
' Get the selection preferences object
Set ACADPref = ThisDrawing.Application.Preferences.Selection
originalValue = ACADPref.PickDrag
MsgBox "The PickDrag preference is set to: " & originalValue
' Modify the PickDrag preference by toggling the value
ACADPref.PickDrag = Not (ACADPref.PickDrag)
newValue = ACADPref.PickDrag
MsgBox "The PickDrag preference has been set to: " & newValue
' this preference in effect
ACADPref.PickDrag = originalValue
MsgBox "The PickDrag preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_PickDrag()
;; This example reads and modifies the preference value that controls
;; the method of drawing a selection window.
;; When finished, this example resets the preference value back to
;; its original value.
(setq originalValue (vla-get-PickDrag (vla-get-Selection preferences)))
(alert (strcat "The PickDrag preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the PickDrag preference by toggling the value
(vla-put-PickDrag (vla-get-Selection preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(setq newValue (vla-get-PickDrag (vla-get-Selection preferences)))
(alert (strcat "The PickDrag preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
;; this preference in effect
(vla-put-PickDrag (vla-get-Selection preferences) originalValue)
(alert (strcat "The PickDrag preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-10-28 06:09
