PickAuto 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 911| 评论: 0|原作者: admin|来自: AutoCAD
在“选择对象”提示下控制自动窗口。
object.PickAuto
类型:首选项选择
此属性应用于的对象。
只读:不
类型:布尔
  • True:在“选取对象”(Select Objects) 提示下自动绘制选取窗口(用于窗口或交叉选取)。
  • False:禁用 PickAuto。
此属性的初始值为 。True
注意:此属性的值存储在 PICKAUTO 系统变量中。
Sub Example_PickAuto()
    ' This example reads and modifies the preference value that controls
    ' automatic windowing at the Select Objects prompt.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesSelection
    ' Get the selection preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.Selection
    originalValue = ACADPref.PickAuto
    MsgBox "The PickAuto preference is set to: " & originalValue
    ' Modify the PickAuto preference by toggling the value
    ACADPref.PickAuto = Not (ACADPref.PickAuto)
    newValue = ACADPref.PickAuto
    MsgBox "The PickAuto preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.PickAuto = originalValue
    MsgBox "The PickAuto preference was reset back to: " & originalValue
(defun c:Example_PickAuto()
    ;; This example reads and modifies the preference value that controls
    ;; automatic windowing at the Select Objects prompt.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    (setq originalValue (vla-get-PickAuto (vla-get-Selection preferences)))
    (alert (strcat "The PickAuto preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the PickAuto preference by toggling the value
    (vla-put-PickAuto (vla-get-Selection preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-PickAuto (vla-get-Selection preferences)))
    (alert (strcat "The PickAuto preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
    ;;         this preference in effect
    (vla-put-PickAuto (vla-get-Selection preferences) originalValue)
    (alert (strcat "The PickAuto preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-10-27 16:05
