PatternSpace 属性 (ActiveX)
指定用户定义的填充图案间距。 支持的平台:仅限 Windows 属性值只读:不 类型:双 填充图案间距。 言论如果该属性设置为 或 ,则不使用该属性。PatternTypeacHatchPatternTypePreDefinedacHatchPatternTypeCustomDefinedPatternSpace 注意:此属性的值是从 HPSPACE 系统变量设置的。
例子VBA: Sub Example_PatternSpace()
' This example creates an associative hatch in model space.
' The spacing of the hatch pattern is then returned and changed.
Dim hatchObj As AcadHatch
Dim patternName As String
Dim PatternType As Long
Dim bAssociativity As Boolean
' Define the hatch
patternName = "ANSI31"
PatternType = 0
bAssociativity = True
' Create the associative Hatch object
Set hatchObj = ThisDrawing.ModelSpace.AddHatch(PatternType, patternName, bAssociativity)
' Create the outer loop for the hatch.
' An arc and a line are used to create a closed loop.
Dim outerLoop(0 To 1) As AcadEntity
Dim center(0 To 2) As Double
Dim radius As Double
Dim startAngle As Double
Dim endAngle As Double
center(0) = 5: center(1) = 3: center(2) = 0
radius = 3
startAngle = 0
endAngle = 3.141592
Set outerLoop(0) = ThisDrawing.ModelSpace.AddArc(center, radius, startAngle, endAngle)
Set outerLoop(1) = ThisDrawing.ModelSpace.AddLine(outerLoop(0).startPoint, outerLoop(0).endPoint)
' Append the outer loop to the hatch object
hatchObj.AppendOuterLoop (outerLoop)
' Append the first circle as one inner loop
Dim innerLoop1(0) As AcadEntity
center(0) = 5: center(1) = 4.5: center(2) = 0
radius = 1
Set innerLoop1(0) = ThisDrawing.ModelSpace.AddCircle(center, radius)
hatchObj.AppendInnerLoop (innerLoop1)
' Append the second circle as the other inner loop
Dim innerLoop2(0) As AcadEntity
radius = 0.5
Set innerLoop2(0) = ThisDrawing.ModelSpace.AddCircle(center, radius)
hatchObj.AppendInnerLoop (innerLoop2)
' Evaluate and display the hatch
hatchObj.Evaluate
ThisDrawing.Regen True
' Find the space of the hatch pattern
Dim patternSpace As Double
patternSpace = hatchObj.patternSpace
MsgBox "The spacing of the hatch pattern is " & hatchObj.patternSpace, , "PatternSpace Example"
' Change the spacing of the hatch pattern
hatchObj.patternSpace = patternSpace + 2
hatchObj.Evaluate
MsgBox "The spacing of the hatch pattern is now " & hatchObj.patternSpace, , "PatternSpace Example"
可视化 LISP: (vl-load-com)
(defun c:Example_PatternSpace()
;; This example creates an associative hatch in model space.
;; The spacing of the hatch pattern is then returned and changed.
;; Define the hatch
(setq patternName "ANSI31"
patternType 0
bAssociativity :vlax-true)
;; Create the associative Hatch object
(setq hatchObj (vla-AddHatch modelSpace patternType patternName bAssociativity acHatchObject))
;; Create the outer loop for the hatch.
;; An arc and a line are used to create a closed loop.
(setq center (vlax-3d-point 5 3 0)
radius 3
startAngle 0
endAngle 3.141592)
(setq arc (vla-AddArc modelSpace center radius startAngle endAngle))
(setq line (vla-AddLine modelSpace (vla-get-StartPoint arc) (vla-get-EndPoint arc)))
(setq outerLoop (vlax-make-safearray vlax-vbObject '(0 . 1)))
(vlax-safearray-put-element outerLoop 0 arc)
(vlax-safearray-put-element outerLoop 1 line)
;; Append the outer loop to the hatch object
(vla-AppendOuterLoop hatchObj outerLoop)
;; Append the first circle as one inner loop
(setq center (vlax-3d-point 5 4.5 0)
radius 1)
(setq circle1 (vla-AddCircle modelSpace center radius))
(setq innerLoop1 (vlax-make-safearray vlax-vbObject '(0 . 0)))
(vlax-safearray-put-element innerLoop1 0 circle1)
(vla-AppendInnerLoop hatchObj innerLoop1)
;; Append the second circle as the other inner loop
(setq radius 0.5)
(setq innerLoop2 (vlax-make-safearray vlax-vbObject '(0 . 0)))
(setq circle2 (vla-AddCircle modelSpace center radius))
(vlax-safearray-put-element innerLoop2 0 circle2)
(vla-AppendInnerLoop hatchObj innerLoop2)
;; Evaluate and display the hatch
(vla-Evaluate hatchObj)
(vla-Regen doc :vlax-true)
;; Find the space of the hatch pattern
(setq patternSpace (vla-get-PatternSpace hatchObj))
(alert (strcat "The spacing of the hatch pattern is " (rtos patternSpace 2)))
;; Change the spacing of the hatch pattern
(vla-put-PatternSpace hatchObj (+ patternSpace 2))
(alert (strcat "The spacing of the hatch pattern is now " (rtos (vla-get-PatternSpace hatchObj) 2)))
GMT+8, 2026-10-27 14:27
