Path 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 624| 评论: 0|原作者: admin|来自: AutoCAD
Path 属性 (ActiveX)
获取块、文档、应用程序或外部引用的路径。
object.Path
类型:应用程序、块、文档、外部引用、点云、点云Ex
此属性应用于的对象。
只读:是的;除了 和 对象ExternalReferenceBlock
类型:字符串
应用程序、文档或外部引用的路径。
Sub Example_Path()
    ' This example returns the path of the drawing and application.
    ' If the drawing has not been saved, the path of the
    ' document will be blank.
    Dim docPath As String
    docPath = ThisDrawing.Path
    MsgBox "The Path of the current drawing is " & docPath, , "Path Example"
    Dim appPath As String
    appPath = ThisDrawing.Application.Path
    MsgBox "The Path of the current appication is " & appPath, , "Path Example"
(defun c:Example_Path()
    ;; This example returns the path of the drawing and application.
    ;; If the drawing has not been saved, the path of the
    ;; document will be blank.
    (setq docPath (vla-get-Path doc))
    (alert (strcat "The Path of the current drawing is " docPath))
    (setq appPath (vla-get-Path acadObj))
    (alert (strcat "The Path of the current appication is " appPath))
GMT+8, 2026-10-27 16:03
