Parent 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 678| 评论: 0|原作者: admin|来自: AutoCAD
Parent 属性 (ActiveX)
获取对象的父级。
object.Parent
类型:MenuBar、MenuGroup、MenuGroups、PopupMenu、PopupMenuItem、PopupMenus、Toolbar、ToolbarItem、Toolbars
此属性应用于的对象。
只读:是/否
类型:对象
用户指定的变量必须声明为适当的对象类型。有效的对象类型包括:Application、MenuBar、MenuGroup、MenuGroups、PopupMenu、PopupMenus、Toolbar、Toolbars
Sub Example_Parent()
    ' This example creates a new toolbar and then finds the parent toolbar.
    ' To remove the toolbar after execution of this macro, use the Customize Menu
    ' option from the Tools menu.
    Dim currMenuGroup As acadMenuGroup
    Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
    ' Create the new toolbar
    Dim newToolBar As AcadToolbar
    Set newToolBar = currMenuGroup.Toolbars.Add("MyTools")
    ' Add a button to the new toolbar.
    ' All three buttons will have the same macro attached.
    Dim newButton1 As AcadToolbarItem
    Dim openMacro As String
    ' Assign the macro string the VB equivalent of "ESC ESC _open "
    openMacro = Chr(3) & Chr(3) & Chr(95) & "open" & Chr(32)
    Set newButton1 = newToolBar.AddToolbarButton("", "OpenFile", "Open a file.", openMacro)
    ' Display the toolbar
    newToolBar.Visible = True
    ' Find the parent toolbar for the toolbar button
    MsgBox "The " & newButton1.name & " button is on the " & newButton1.Parent.name & " toolbar."
(defun c:Example_Parent()
    ;; This example creates a new toolbar and then finds the parent toolbar.
    ;; To remove the toolbar after execution of this macro, use the Customize Menu
    ;; option from the Tools menu.
    (setq currMenuGroup (vla-Item (vla-get-MenuGroups acadObj) 0))
    ;; Create the new toolbar
    (setq newToolBar (vla-Add (vla-get-Toolbars currMenuGroup) "MyTools"))
    ;; Add a button to the new toolbar.
    ;; All three buttons will have the same macro attached.
    ;; Assign the macro string the VB equivalent of "ESC ESC _open "
    (setq openMacro (strcat (Chr 3) (Chr 3) (Chr 95) "open" (Chr 32)))
    (setq newButton1 (vla-AddToolbarButton newToolBar "" "OpenFile" "Open a file." openMacro))
    ;; Display the toolbar
    (vla-put-Visible newToolBar :vlax-true)
    ;; Find the parent toolbar for the toolbar button
    (alert (strcat "The " (vla-get-Name newButton1) " button is on the " (vla-get-Name (vla-get-Parent newButton1)) " toolbar."))
GMT+8, 2026-11-11 04:55
