PaperUnits 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 790| 评论: 0|原作者: admin|来自: AutoCAD
指定用于显示布局或打印配置属性的单位。
object.PaperUnits
类型:布局、PlotConfiguration
此属性应用于的对象。
只读:不
类型:枚举acPlotPaperUnits
  • acInches
  • acMillimeters
  • acPixels
此属性确定在用户界面中显示布局或打印配置的单位。此属性不确定 ActiveX 自动化属性的输入或查询的单位。所有 ActiveX 自动化属性都以毫米或弧度表示,无论单位设置如何。
在重新生成图形之前,对此属性的更改将不可见。使用该方法重新生成图形。Regen
Sub Example_PaperUnits()
    ' This example will access the Layouts collection for the current drawing
    ' and list basic information about the paper units used for each Layout.
    Dim Layouts As AcadLayouts, Layout As ACADLayout
    Dim msg As String
    Dim Measurement As String
    ' Get layouts collection from document object
    Set Layouts = ThisDrawing.Layouts
    msg = vbCrLf   ' Start with a space
    ' Get the paper units information of every layout in this drawing
    For Each Layout In Layouts
        ' Using inches or millimeters?
        Measurement = IIf(Layout.PaperUnits = acInches, " inches", " millimeters")
        ' Format for display
        msg = msg & Layout.name & " is using" & Measurement & vbCrLf
    Next
    ' Display paper units information
    MsgBox "The paper units used in the current drawing are: " & msg
(defun c:Example_PaperUnits()
    ;; This example will access the Layouts collection for the current drawing
    ;; and list basic information about the paper units used for each Layout.
    ;; Get layouts collection from document object
    (setq Layouts (vla-get-Layouts doc))
    (setq msg ""
          Measurement "")
    ;; Get the paper units information of every layout in this drawing
    (vlax-for Layout Layouts
        ;; Using inches or millimeters?
        (setq Measurement (if (= (vla-get-PaperUnits Layout) acInches) " inches" " millimeters"))
        ;; Format for display
        (setq msg (strcat msg (vla-get-Name Layout) " is using" Measurement "\n"))
    ;; Display paper units information
    (alert (strcat "The paper units used in the current drawing are: \n" msg))
GMT+8, 2026-10-27 15:10
