PaperSpace 属性 (ActiveX)
获取文档的 PaperSpace 集合。 支持的平台:仅限 Windows 言论没有其他评论。 例子VBA: Sub Example_PaperSpace()
' This example sets the variable pspace to the paper space object collection.
Dim pspace As AcadPaperSpace
Set pspace = ThisDrawing.PaperSpace
可视化 LISP: (vl-load-com)
(defun c:Example_PaperSpace()
;; This example sets the variable pspace to the paper space object collection.
(setq pspace (vla-get-PaperSpace doc))
GMT+8, 2026-10-27 14:19
