OpenSave 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 745| 评论: 0|原作者: admin|来自: AutoCAD
获取 PreferencesOpenSave 对象。
object.OpenSave
类型:首选项
此属性应用于的对象。
只读:是的
类型:PreferencesOpenSave
获取对象。PreferencesOpenSave
该对象保存存储在注册表中的“选项”对话框的“打开和保存”选项卡中的所有选项。与图形一起存储的所有选项都可以在对象上找到。PreferencesOpenSaveDatabasePreferences
Sub Example_OpenSave()
    ' This example obtains a reference to the OpenSave Preferences object
    ' from the Application Preferences object, and reads one of the OpenSave
    ' preferences
    Dim ACADPref As AcadPreferencesOpenSave
    ' Obtain a reference to the OpenSave Preferences object
    Set ACADPref = ThisDrawing.Application.preferences.OpenSave
    MsgBox "You now have access to the properties and methods of the OpenSave Preferences object!"
    MsgBox "The OpenSave preference TempFileExtension is set to: " & ACADPref.TempFileExtension
Not available
GMT+8, 2026-10-27 15:07
