OnMenuBar 属性 (ActiveX)
确定指定的弹出菜单是否位于菜单栏上。 支持的平台:仅限 Windows 属性值只读:是的 类型:布尔
言论没有其他评论。 例子VBA: Sub Example_OnMenuBar()
' This example creates a new menu called TestMenu and inserts a menu item
' into it. The menu is then displayed on the menu bar, and then
' removed from the menu bar.
Dim currMenuGroup As acadMenuGroup
Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
' Create the new menu
Dim newMenu As AcadPopupMenu
Set newMenu = currMenuGroup.Menus.Add("TestMenu")
' Add a menu item to the new menu
Dim newMenuItem As AcadPopupMenuItem
Dim openMacro As String
' Assign the macro string the VB equivalent of "ESC ESC _open "
openMacro = Chr(3) & Chr(3) & Chr(95) & "open" & Chr(32)
Set newMenuItem = newMenu.AddMenuItem(newMenu.count + 1, "Open", openMacro)
' Display the menu on the menu bar
newMenu.InsertInMenuBar (ThisDrawing.Application.MenuBar.count + 1)
GoSub QUERYMENU
' Remove the menu from the menu bar
currMenuGroup.Menus.RemoveMenuFromMenuBar ("TestMenu")
GoSub QUERYMENU
Exit Sub
QUERYMENU:
If newMenu.OnMenuBar Then
MsgBox "The menu called " & newMenu.name & " is on the menu bar."
Else
MsgBox "The menu called " & newMenu.name & " is not on the menu bar."
End If
Return
可视化 LISP: (vl-load-com)
(defun c:Example_OnMenuBar()
;; This example creates a new menu called TestMenu and inserts a menu item
;; into it. The menu is then displayed on the menu bar, and then
;; removed from the menu bar.
(setq currMenuGroup (vla-Item (vla-get-MenuGroups acadObj) 0))
;; Create the new menu
(setq newMenu (vla-Add (vla-get-Menus currMenuGroup) "TestMenu"))
;; Add a menu item to the new menu
;; Assign the macro string the VB equivalent of "ESC ESC _open "
(setq openMacro (strcat (Chr 3) (Chr 3) (Chr 95) "open" (Chr 32)))
(setq newMenuItem (vla-AddMenuItem newMenu (1+ (vla-get-Count newMenu)) "Open" openMacro))
;; Display the menu on the menu bar
(vla-InsertInMenuBar newMenu (1+ (vla-get-Count (vla-get-MenuBar acadObj))))
(if (= (vla-get-OnMenuBar newMenu) :vlax-true)
(alert (strcat "The menu called " (vla-get-Name newMenu) " is on the menu bar."))
(alert (strcat "The menu called " (vla-get-Name newMenu) " is not on the menu bar."))
;; Remove the menu from the menu bar
(vla-RemoveMenuFromMenuBar (vla-get-Menus currMenuGroup) "TestMenu")
GMT+8, 2026-10-26 13:45
