OLEQuality 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 740| 评论: 0|原作者: admin|来自: AutoCAD
指定 OLE 对象的打印质量。
object.OLEQuality
类型:首选项输出
此属性应用于的对象。
只读:不
类型:枚举acOleQuality
  • acOQLineArt
  • acOQText
  • acOQGraphics
  • acOQPhoto
  • acOQHighPhoto
此属性的初始值为 。acOQText
注意:此属性的值存储在 OLEQUALITY 系统变量中。
Sub Example_OLEQuality()
    ' This example reads and modifies the preference value that controls
    ' the plot quality of OLE objects. When finished, this example resets
    ' the preference value back to its original value.
    Dim ACADPref As AcadPreferencesOutput
    Dim originalValue As Variant, DisplayValue As String
    ' Get the output preferences object
    Set ACADPref = ThisDrawing.Application.preferences.Output
    ' Store original value
    originalValue = ACADPref.OLEQuality
    GoSub GETVALUE
    MsgBox "The OLEQuality preference is currently set to: " & DisplayValue
    ' Modify the OLEQuality preference by changing it to High Quality Photographic
    ACADPref.OLEQuality = acOQHighPhoto
    GoSub GETVALUE
    MsgBox "The OLEQuality preference has been set to: " & DisplayValue
    '         this preference in effect
    ACADPref.OLEQuality = originalValue
    GoSub GETVALUE
    MsgBox "The OLEQuality preference was reset back to: " & DisplayValue
    Exit Sub
GETVALUE:
    ' Convert the value of this setting to a meaningful text string
    DisplayValue = ACADPref.OLEQuality
    Select Case DisplayValue
        Case acOQLineArt: DisplayValue = "Line Art"
        Case acOQText: DisplayValue = "Text"
        Case acOQGraphics: DisplayValue = "Graphics"
        Case acOQPhoto: DisplayValue = "Photo"
        Case acOQHighPhoto: DisplayValue = "High Photo"
    End Select
    Return
(defun c:Example_OLEQuality()
    ;; This example reads and modifies the preference value that controls
    ;; the plot quality of OLE objects. When finished, this example resets
    ;; the preference value back to its original value.
    ;; Store original value
    (setq originalValue (vla-get-OLEQuality (vla-get-Output preferences)))
    (setq DisplayValue (cond
                           ((= (vla-get-OLEQuality (vla-get-Output preferences)) acOQLineArt) "Line Art")
                           ((= (vla-get-OLEQuality (vla-get-Output preferences)) acOQText) "Text")
                           ((= (vla-get-OLEQuality (vla-get-Output preferences)) acOQGraphics) "Graphics")
                           ((= (vla-get-OLEQuality (vla-get-Output preferences)) acOQPhoto) "Photo")
                           ((= (vla-get-OLEQuality (vla-get-Output preferences)) acOQHighPhoto) "High Photo")
    (alert (strcat "The OLEQuality preference is currently set to: " DisplayValue))
    ;; Modify the OLEQuality preference by changing it to High Quality Photographic
    (vla-put-OLEQuality (vla-get-Output preferences) acOQHighPhoto)
    (alert (strcat "The OLEQuality preference has been set to: " DisplayValue))
    ;;         this preference in effect
    (vla-put-OLEQuality (vla-get-Output preferences) originalValue)
    (alert (strcat "The OLEQuality preference was reset back to: " DisplayValue))
GMT+8, 2026-10-28 09:02
