ObjectSnapMode 属性 (ActiveX)
指定对象捕捉模式的设置。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论没有其他评论。 例子VBA: Sub Example_ObjectSnapMode()
' This example toggles the setting of the Object Snap Mode.
Dim currObjSnapMode As Boolean
' Get the current ObjectSnapMode value
currObjSnapMode = ThisDrawing.ObjectSnapMode
MsgBox "The object snap mode is currently " & IIf(ThisDrawing.ObjectSnapMode, "on.", "off."), , "ObjectSnapMode Example"
' Change the default ObjectSnapMode value
ThisDrawing.ObjectSnapMode = Not (currObjSnapMode)
MsgBox "The object snap mode is now " & IIf(ThisDrawing.ObjectSnapMode, "on.", "off."), , "ObjectSnapMode Example"
可视化 LISP: (vl-load-com)
(defun c:Example_ObjectSnapMode()
;; This example toggles the setting of the Object Snap Mode.
;; Get the current ObjectSnapMode value
(setq currObjSnapMode (vla-get-ObjectSnapMode doc))
(alert (strcat "The object snap mode is currently " (if (= (vla-get-ObjectSnapMode doc) :vlax-true) "on." "off.")))
;; Change the default ObjectSnapMode value
(vla-put-ObjectSnapMode doc (if (= (vla-get-ObjectSnapMode doc) :vlax-true) :vlax-false :vlax-true))
(alert (strcat "The object snap mode is now " (if (= (vla-get-ObjectSnapMode doc) :vlax-true) "on." "off.")))
GMT+8, 2026-10-29 23:52
