NumberOfCopies 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 789| 评论: 0|原作者: admin|来自: AutoCAD
指定要打印的副本数。
object.NumberOfCopies
类型: 剧情
此属性应用于的对象。
只读:不
类型:长
要打印的副本数。
Sub Example_NumberOfCopies()
    ' This example plots the layouts of a drawing.
    Dim oPlot As AcadPlot
    Dim AddedLayouts() As String
    Dim LayoutList As Variant
    Dim oLayout As AcadLayout
    Dim ArraySize As Integer, BatchCount As Integer
    For Each oLayout In ThisDrawing.Layouts
        ArraySize = ArraySize + 1
        ReDim Preserve AddedLayouts(1 To ArraySize)
        AddedLayouts(ArraySize) = oLayout.Name
    Next
    LayoutList = AddedLayouts
    Set oPlot = ThisDrawing.Plot
    oPlot.SetLayoutsToPlot LayoutList
    oPlot.PlotToDevice "DWF6 ePlot.pc3"
(defun c:Example_NumberOfCopies()
    ;; This example plots the layouts of a drawing.
    (setq AddedLayouts (vlax-make-safearray vlax-vbString (cons 0 (1- (vla-get-Count (vla-get-Layouts doc)))))
          ArraySize 0)
    (vlax-for oLayout (vla-get-Layouts doc)
        (vlax-safearray-put-element AddedLayouts ArraySize (vla-get-Name oLayout))
        (setq ArraySize (1+ ArraySize))
    (setq oPlot (vla-get-Plot doc))
    (vla-SetLayoutsToPlot oPlot AddedLayouts)
    (vla-PlotToDevice oPlot "DWF6 ePlot.pc3")
GMT+8, 2026-10-28 20:24
