NumberOfControlPoints 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 874| 评论: 0|原作者: admin|来自: AutoCAD
获取样条的控制点数。
object.NumberOfControlPoints
类型:样条曲线
此属性应用于的对象。
只读:是的
类型:整数
样条的控制点数。
控制点通过向样条曲线的一部分添加权重来微调样条定义。
您可以使用该方法查询控制点的当前位置。您可以使用该方法为控制点设置新的坐标位置。您可以使用该方法为控制点设置新权重。GetControlPointSetControlPointSetWeight
Sub Example_NumberOfControlPoints()
    ' This example creates a spline object in model space.
    ' It then finds the number of control points for that spline.
    ' Create the spline
    Dim splineObj As AcadSpline
    Dim startTan(0 To 2) As Double
    Dim endTan(0 To 2) As Double
    Dim fitPoints(0 To 8) As Double
    startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
    endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
    fitPoints(0) = 1: fitPoints(1) = 1: fitPoints(2) = 0
    fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0
    fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
    Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
    ZoomAll
    MsgBox "The Spline has " & splineObj.NumberOfControlPoints & " control points.", , "NumberOfControlPoints Example"
(defun c:Example_NumberOfControlPoints()
    ;; This example creates a spline object in model space.
    ;; It then finds the number of control points for that spline.
    ;; Create the spline
    (setq startTan (vlax-3d-point 0.5 0.5 0)
          endTan (vlax-3d-point 0.5 0.5 0)
          fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
    (vlax-safearray-fill fitPoints '(1 1 0
				     5 5 0
				     10 0 0
    (setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
    (vla-ZoomAll acadObj)
    (alert (strcat "The Spline has " (itoa (vla-get-NumberOfControlPoints splineObj)) " control points."))
GMT+8, 2026-11-11 04:55
