Normal 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 810| 评论: 0|原作者: admin|来自: AutoCAD
Normal 属性 (ActiveX)
指定对象的三维法线单位向量。
object.Normal
类型:属性属性、 Reference、 块引用Dim3PointAngularDimAlignedDimAngularDimArcLengthDimDiametric尺寸DimOrdinateDim径向DimRadialLargeDimRotated椭圆ExternalReference剖面线引线线LWPolylineMInsertBlockMText折线区域部分形状实体文本公差跟踪
此属性应用于的对象。
只读:
类型:变体(双打的三元素阵列)
WCS 中的 3D 法向单位向量。
此法向量定义给定对象的 Z 轴。尽管在 WCS 中返回法线,但它可用于确定对象的 OCS。在将坐标与 OCS 相互转换时,在方法中使用此属性作为 OCSNormal。TranslateCoordinates
请注意,此属性指定向量,而不是点。向量定义法线的方向,而不是空间中的位置。您可以将此法向量添加到一个点以获得另一个点。
公差:法向量必须垂直于物体的方向。不垂直于 Tolerance 对象的法线将生成错误。Tolerance
Sub Example_Normal()
    ' This example creates a circle in model space.
    ' It then finds the current normal to that circle
    ' and changes the normal.
    ' Define a circle
    Dim circleObj As AcadCircle
    Dim center(0 To 2) As Double
    Dim radius As Double
    center(0) = 4: center(1) = 4: center(2) = 0
    radius = 1
    ' Add the circle to model space
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(center, radius)
    ZoomAll
    ' Find the normal for the circle
    Dim currNormal As Variant
    currNormal = circleObj.Normal
    MsgBox "The current normal for the circle is " & circleObj.Normal(0) & ", " & circleObj.Normal(1) & ", " & circleObj.Normal(2), , "Normal Example"
    ' Change the normal for the circle
    Dim newNormal(0 To 2) As Double
    newNormal(0) = 1: newNormal(1) = 1: newNormal(2) = -1
    circleObj.Normal = newNormal
    circleObj.Update
(defun c:Example_Normal()
    ;; This example creates a circle in model space.
    ;; It then finds the current normal to that circle
    ;; and changes the normal.
    ;; Define a circle
    (setq center (vlax-3d-point 4 4 0)
          radius 1)
    ;; Add the circle to model space
    (setq circleObj (vla-AddCircle modelSpace center radius))
    (vla-ZoomAll acadObj)
    ;; Find the normal for the circle
    (setq currNormal (vlax-variant-value (vla-get-Normal circleObj)))
    (alert (strcat "The current normal for the circle is " (rtos (vlax-safearray-get-element currNormal 0) 2) ", "
                                                           (rtos (vlax-safearray-get-element currNormal 1) 2) ", "
                                                           (rtos (vlax-safearray-get-element currNormal 2) 2)))
    ;; Change the normal for the circle
    (setq newNormal (vlax-3d-point 1 1 -1))
    (vla-put-Normal circleObj newNormal)
    (vla-Update circleObj)
    (setq newNormal (vlax-variant-value newNormal))
    (alert (strcat "The current normal for the circle is " (rtos (vlax-safearray-get-element newNormal 0) 2) ", "
                                                           (rtos (vlax-safearray-get-element newNormal 1) 2) ", "
                                                           (rtos (vlax-safearray-get-element newNormal 2) 2)))
GMT+8, 2026-9-11 00:02
