NameNoMnemonic 属性 (ActiveX)
指定不带下划线助记符的弹出菜单的名称。 支持的平台:仅限 Windows 属性值只读:是的 类型:字符串 不带下划线助记符的弹出菜单名称。 言论没有其他评论。 例子VBA: Sub Example_NameNoMnemonic()
' This example iterates through the menus collection and
' displays the Name and NameNoMnemonic property for each menu.
' Note that depending on how many menus are currently loaded, the
' menuStatus string may not be displayed in full.
Dim currMenu As AcadPopupMenu
Dim menuStatus As String
menuStatus = ""
For Each currMenu In ThisDrawing.Application.MenuGroups.Item(0).Menus
menuStatus = menuStatus & currMenu.name & " -- " & currMenu.NameNoMnemonic & vbCrLf
Next currMenu
MsgBox menuStatus
可视化 LISP: (vl-load-com)
(defun c:Example_NameNoMnemonic()
;; This example iterates through the menus collection and
;; displays the Name and NameNoMnemonic property for each menu.
;; Note that depending on how many menus are currently loaded, the
;; menuStatus string may not be displayed in full.
(setq menuStatus "")
(vlax-for currMenu (vla-get-Menus (vla-Item (vla-get-MenuGroups acadObj) 0))
(setq menuStatus (strcat menuStatus (vla-get-Name currMenu) " -- " (vla-get-NameNoMnemonic currMenu) "\n"))
(alert menuStatus)
GMT+8, 2026-10-27 13:25
