MTextAttributeContent 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 930| 评论: 0|原作者: admin|来自: AutoCAD
获取多行属性内容。
object.MTextAttributeContent
类型:Attribute、AttributeReference
此方法应用到的对象。
只读:不
类型:字符串
属性的内容。
Sub Example_MTextAttribute()
    ' This example creates an attribute definition in model space.
    ' It then manipulates its MText properties
    Dim attributeObj As IAcadAttribute
    Dim height As Double
    Dim mode As Long
    Dim prompt As String
    Dim tag As String
    Dim value As String
    ' Define the attribute definition
    height = 1.4
    mode = acAttributeModeVerify
    prompt = "New Prompt"
    insertionPoint(0) = 5.2: insertionPoint(1) = 5.7: insertionPoint(2) = 0
    tag = "NEW_TAG"
    value = "New Value"
    ' Create the attribute definition object in model space
    Set attributeObj = ThisDrawing.ModelSpace.AddAttribute(height, mode, prompt, insertionPoint, tag, value)
    attributeObj.MTextAttribute = True
    attributeObj.MTextAttributeContent = "test content"
    attributeObj.MTextBoundaryWidth = 4.2
    attributeObj.UpdateMTextAttribute
    ZoomAll
(defun c:Example_MTextAttribute()
    ;; This example creates an attribute definition in model space.
    ;; It then manipulates its MText properties
    ;; Define the attribute definition
    (setq insertionPoint (vlax-3d-point 5.2 5.7 0)
          attHeight 1.4
          attMode (+ acAttributeModeVerify acAttributeModeMultipleLine)
          attPrompt "New Prompt"
          attTag "NEW_TAG"
          attValue "New Value")
    ;; Create the attribute definition object in model space
    (setq attributeObj (vla-AddAttribute modelSpace attHeight attMode attPrompt insertionPoint attTag attValue))
    (vla-put-MTextAttributeContent attributeObj "test content")
    (vla-put-MTextBoundaryWidth attributeObj 4.2)
    (vla-UpdateMTextAttribute attributeObj)
    (vla-ZoomAll acadObj)
GMT+8, 2026-10-26 12:58
