MSpace 属性 (ActiveX)
允许从浮动图纸空间视口编辑模型。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论AutoCAD 在模型空间或图纸空间中运行。使用模型空间进行绘图和设计工作,并创建 2D 工程图或 3D 模型。使用图纸空间创建图形的完成布局以进行打印或打印。 注意:在使用该属性之前,必须将该属性设置为 ,并且该属性必须打开对象的显示控件。MSpaceActiveSpaceacPaperSpacePViewportDisplay
例子VBA: Sub Example_MSpace()
' This example creates a new paper space viewport.
' It then toggles the ability to edit in model space using
' the MSpace property.
Dim pviewportObj As AcadPViewport
Dim center(0 To 2) As Double
Dim width As Double
Dim height As Double
' Define the paper space viewport
center(0) = 3: center(1) = 3: center(2) = 0
width = 40
height = 40
' Change from model space to paperspace
ThisDrawing.ActiveSpace = acPaperSpace
' Create the paper space viewport
Set pviewportObj = ThisDrawing.PaperSpace.AddPViewport(center, width, height)
pviewportObj.DISPLAY True
ThisDrawing.mspace = True
ThisDrawing.ActivePViewport = pviewportObj
' Find the current MSpace value
MsgBox "The ability to edit model space from this PViewport is " & IIf(ThisDrawing.mspace, "on.", "off."), , "MSpace Example"
' Toggle the setting of MSpace
ThisDrawing.mspace = False
MsgBox "The ability to edit model space from this PViewport is now " & IIf(ThisDrawing.mspace, "on.", "off."), , "MSpace Example"
可视化 LISP: (vl-load-com)
(defun c:Example_MSpace()
;; This example creates a new paper space viewport.
;; It then toggles the ability to edit in model space using
;; the MSpace property.
;; Define the paper space viewport
(setq center (vlax-3d-point 3 3 0)
width 40
height 40)
;; Change from model space to paperspace
(vla-put-ActiveSpace doc acPaperSpace)
;; Create the paper space viewport
(setq paperSpace (vla-get-PaperSpace doc))
(setq pviewportObj (vla-AddPViewport paperSpace center width height))
(vla-Display pviewportObj :vlax-true)
(vla-put-MSpace doc :vlax-true)
(vla-put-ActivePViewport doc pviewportObj)
;; Find the current MSpace value
(alert (strcat "The ability to edit model space from this PViewport is " (if (= (vla-get-MSpace doc) :vlax-true) "on." "off.")))
;; Toggle the setting of MSpace
(vla-put-MSpace doc :vlax-false)
(alert (strcat "The ability to edit model space from this PViewport is now " (if (= (vla-get-MSpace doc) :vlax-true) "on." "off.")))
GMT+8, 2026-10-28 00:05
