ModelCrosshairColor 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 769| 评论: 0|原作者: admin|来自: AutoCAD
指定模型空间的十字准线和文本的颜色。
object.ModelCrosshairColor
类型:首选项显示
此属性应用于的对象。
只读:不
类型:OLE_COLOR(常量)
  • vbBlack
  • vbRed
  • vbYellow
  • vbGreen
  • vbCyan
  • vbBlue
  • vbMagenta
  • vbWhite
此属性的初始值为 。vbWhite
若要指定图纸空间布局的十字准线颜色,请使用该属性。LayoutCrosshairColor
Sub Example_ModelCrossHairColor()
    ' Model space CrossHairColor. It then changes the value, and
    ' finally resets the value back to the original setting.
    Dim currCrossHairColor As OLE_COLOR
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current CrossHairColor value
    currCrossHairColor = preferences.DISPLAY.ModelCrosshairColor
    MsgBox "The current value for the model space CrossHairColor is " & preferences.DISPLAY.ModelCrosshairColor, vbInformation, "CrossHairColor Example"
    ' Change the value for CrossHairColor
    preferences.DISPLAY.ModelCrosshairColor = vbGreen
    MsgBox "The new value for CrossHairColor is " & preferences.DISPLAY.ModelCrosshairColor, vbInformation, "CrossHairColor Example"
    ' Reset CrossHairColor to its original value
    preferences.DISPLAY.ModelCrosshairColor = currCrossHairColor
    MsgBox "The CrossHairColor value is reset to " & preferences.DISPLAY.ModelCrosshairColor, vbInformation, "CrossHairColor Example"
(defun c:Example_ModelCrossHairColor()
    ;; Model space CrossHairColor. It then changes the value, and
    ;; finally resets the value back to the original setting.
    ;; Get the Display preferences object
    (setq ACADPref (vla-get-Display preferences))
    ;; Retrieve the current CrossHairColor value
    (setq currCrossHairColor (vlax-variant-change-type (vla-get-ModelCrosshairColor ACADPref) vlax-vbLong))
    (alert (strcat "The current value for the model space CrossHairColor is " (itoa (vlax-variant-value currCrossHairColor))))
    ;; Change the value for CrossHairColor
    (vla-put-ModelCrosshairColor ACADPref (vlax-make-variant acGreen 19))
    (setq newValue (vlax-variant-change-type (vla-get-ModelCrosshairColor ACADPref) vlax-vbLong))
    (alert (strcat "The new value for CrossHairColor is " (itoa (vlax-variant-value newValue))))
    ;; Reset CrossHairColor to its original value
    (vla-put-ModelCrosshairColor ACADPref (vlax-variant-change-type currCrossHairColor 19))
    (alert (strcat "The CrossHairColor value is reset to " (itoa (vlax-variant-value currCrossHairColor))))
GMT+8, 2026-10-26 18:25
