MinorAxis 属性 (ActiveX)
指定椭圆的短轴方向。 支持的平台:仅限 Windows 属性值只读:是的 类型:变体(双打的三元素阵列) 定义短轴的 3D 向量。向量起源于椭圆中心。 言论椭圆的长轴称为长轴;较短的是短轴。 ![]() 例子VBA: Sub Example_MinorAxis()
' This example creates an ellipse and returns the minor
' axis for that ellipse.
Dim ellObj As AcadEllipse
Dim majAxis(0 To 2) As Double
Dim center(0 To 2) As Double
Dim radRatio As Double
' Create an ellipse in model space
center(0) = 5#: center(1) = 5#: center(2) = 0#
majAxis(0) = 10: majAxis(1) = 20#: majAxis(2) = 0#
radRatio = 0.3
Set ellObj = ThisDrawing.ModelSpace.AddEllipse(center, majAxis, radRatio)
ZoomAll
' Find the minor axis for the ellipse
Dim minorAxis As Variant
minorAxis = ellObj.minorAxis
MsgBox "The ellipse has a minor axis of " & minorAxis(0) & ", " & minorAxis(1) & ", " & minorAxis(2), vbInformation, "MinorAxis Example"
可视化 LISP: (vl-load-com)
(defun c:Example_MinorAxis()
;; This example creates an ellipse and returns the minor
;; axis for that ellipse.
;; Create an ellipse in model space
(setq center (vlax-3d-point 5 5 0)
majAxis (vlax-3d-point 10 20 0)
radRatio 0.3)
(setq ellObj (vla-AddEllipse modelSpace center majAxis radRatio))
(vla-ZoomAll acadObj)
;; Find the minor axis for the ellipse
(setq minorAxis (vlax-variant-value (vla-get-MinorAxis ellObj)))
(alert (strcat "The ellipse has a minor axis of " (rtos (vlax-safearray-get-element minorAxis 0) 2) ", "
(rtos (vlax-safearray-get-element minorAxis 1) 2) ", "
(rtos (vlax-safearray-get-element minorAxis 2) 2)))
GMT+8, 2026-10-27 14:10
