Menus 属性 (ActiveX)
获取 PopupMenus 集合。 支持的平台:仅限 Windows 言论没有其他评论。 例子VBA: Sub Example_Menus()
' This example finds the names of all menus in the first menu group.
Dim menuNames As String
Dim menuCollection As AcadPopupMenus
Dim menu As AcadPopupMenu
Set menuCollection = ThisDrawing.Application.MenuGroups.Item(0).Menus
menuNames = ""
For Each menu In menuCollection
menuNames = menuNames & menu.name & vbCrLf
Next menu
MsgBox menuNames
可视化 LISP: (vl-load-com)
(defun c:Example_Menus()
;; This example finds the names of all menus in the first menu group.
(setq menuCollection (vla-get-Menus (vla-Item (vla-get-MenuGroups acadObj) 0))
menuNames "")
(vlax-for menu menuCollection
(setq menuNames (strcat menuNames (vla-get-Name menu) "\n"))
(alert menuNames)
GMT+8, 2026-10-26 13:39
