MaxActiveViewports 属性 (ActiveX)
指定活动视口的最大数量。 支持的平台:仅限 Windows 属性值只读:不 类型:整数 活动视口的最大数量;2 <= MaxActiveViewports <= 48 言论非活动视口为空白,因此不会重新生成其内容。因此,您可以通过指定一个较低的值来提高性能。初始值为 48。 注意:此属性的值存储在 MAXACTVP 系统变量中。
例子VBA: Sub Example_MaxActiveViewports()
' MaxActiveViewports. It then changes the value, and finally
Dim currMaxActiveViewports As Integer
Dim newMaxActiveViewports As Integer
' Retrieve the current MaxActiveViewports value
currMaxActiveViewports = ThisDrawing.preferences.MaxActiveViewports
MsgBox "The current value for MaxActiveViewports is " & currMaxActiveViewports, vbInformation, "MaxActiveViewports Example"
' Change the value for MaxActiveViewports
newMaxActiveViewports = 20
ThisDrawing.preferences.MaxActiveViewports = newMaxActiveViewports
MsgBox "The new value for MaxActiveViewports is " & newMaxActiveViewports, vbInformation, "MaxActiveViewports Example"
' Reset MaxActiveViewports to its original value
ThisDrawing.preferences.MaxActiveViewports = currMaxActiveViewports
MsgBox "The MaxActiveViewports value is reset to " & currMaxActiveViewports, vbInformation, "MaxActiveViewports Example"
可视化 LISP: (vl-load-com)
(defun c:Example_MaxActiveViewports()
;; MaxActiveViewports. It then changes the value, and finally
(setq preferences (vla-get-Preferences doc))
;; Retrieve the current MaxActiveViewports value
(setq currMaxActiveViewports (vla-get-MaxActiveViewports preferences))
(alert (strcat "The current value for MaxActiveViewports is " (itoa currMaxActiveViewports)))
;; Change the value for MaxActiveViewports
(setq newMaxActiveViewports 20)
(vla-put-MaxActiveViewports preferences newMaxActiveViewports)
(alert (strcat "The new value for MaxActiveViewports is " (itoa newMaxActiveViewports)))
;; Reset MaxActiveViewports to its original value
(vla-put-MaxActiveViewports preferences currMaxActiveViewports)
(alert (strcat "The MaxActiveViewports value is reset to " (itoa currMaxActiveViewports)))
GMT+8, 2026-10-27 12:50
