Material 属性 (ActiveX)
指定材料的名称。 支持的平台:仅限 Windows 签名VBA: object.Material
属性值只读:不 类型:字符串 材料的名称。 言论没有其他评论。 例子VBA: Sub Example_AddMaterial()
Dim oMaterial As AcadMaterial
Dim oMaterials As AcadMaterials
Set oMaterial = ThisDrawing.Materials.Add("TestMaterial")
oMaterial.Description = "This material demonstrates how to add a material to a database."
ThisDrawing.ActiveMaterial = oMaterial
' Display the name and description of the layer
MsgBox oMaterial.Name & " has been added." & vbCrLf & _
"Name: " & vbCrLf & oMaterial.Name & vbCrLf & vbCrLf & _
"Description: " & vbCrLf & _
可视化 LISP: (vl-load-com)
(defun c:Example_Materials()
(setq oMaterial (vla-Add (vla-get-Materials doc) "TestMaterial"))
(vla-put-Description oMaterial "This material demonstrates how to add a material to a database.")
(vla-put-ActiveMaterial doc oMaterial)
;; Display the status of the new layer
(alert (strcat (vla-get-Name oMaterial) " has been added."
"\nName: " (vla-get-Name oMaterial)
"\nDescription: " (vla-get-Description oMaterial)))
GMT+8, 2026-11-15 11:40
