LogFilePath 属性 (ActiveX)
指定日志文件的位置。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 日志文件的驱动器和路径。 言论使用该属性可以启用或禁用日志文件功能。LogFileOn 注意:此属性的值存储在 LOGFILEPATH 系统变量中。
例子VBA: Sub Example_LogFilePath()
' LogFilePath. It then changes the value, and finally
Dim currLogFilePath As String
Dim newLogFilePath As String
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current LogFilePath value
currLogFilePath = preferences.Files.LogFilePath
MsgBox "The current value for LogFilePath is " & currLogFilePath, vbInformation, "LogFilePath Example"
' Change the value for LogFilePath
newLogFilePath = "C:/AutoCAD/"
preferences.Files.LogFilePath = newLogFilePath
MsgBox "The new value for LogFilePath is " & newLogFilePath, vbInformation, "LogFilePath Example"
' Reset LogFilePath to its original value
preferences.Files.LogFilePath = currLogFilePath
MsgBox "The LogFilePath value is reset to " & currLogFilePath, vbInformation, "LogFilePath Example"
可视化 LISP: (vl-load-com)
(defun c:Example_LogFilePath()
;; LogFilePath. It then changes the value, and finally
;; Retrieve the current LogFilePath value
(setq currLogFilePath (vla-get-LogFilePath (vla-get-Files preferences)))
(alert (strcat "The current value for LogFilePath is " currLogFilePath))
;; Change the value for LogFilePath
(setq newLogFilePath "C:/AutoCAD/")
(vla-put-LogFilePath (vla-get-Files preferences) newLogFilePath)
(alert (strcat "The new value for LogFilePath is " newLogFilePath))
;; Reset LogFilePath to its original value
(vla-put-LogFilePath (vla-get-Files preferences) currLogFilePath)
(alert (strcat "The LogFilePath value is reset to " currLogFilePath))
GMT+8, 2026-10-27 21:30
