LogFileOn 属性 (ActiveX)
指定是否将文本窗口的内容写入日志文件。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。True 日志文件将文本窗口的内容记录在文本文件中。使用该属性指定日志文件的名称。LogFilePath 注意:此属性的值存储在 LOGFILEMODE 系统变量中。
例子VBA: Sub Example_LogFileOn()
' LogFileOn. It then changes the value, and finally
Dim currLogFileOn As Boolean
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current LogFileOn value
currLogFileOn = preferences.OpenSave.LogFileOn
MsgBox "The current value for LogFileOn is " & preferences.OpenSave.LogFileOn, vbInformation, "LogFileOn Example"
' Change the value for LogFileOn
preferences.OpenSave.LogFileOn = Not (currLogFileOn)
MsgBox "The new value for LogFileOn is " & preferences.OpenSave.LogFileOn, vbInformation, "LogFileOn Example"
' Reset LogFileOn to its original value
preferences.OpenSave.LogFileOn = currLogFileOn
MsgBox "The LogFileOn value is reset to " & preferences.OpenSave.LogFileOn, vbInformation, "LogFileOn Example"
可视化 LISP: (vl-load-com)
(defun c:Example_LogFileOn()
;; LogFileOn. It then changes the value, and finally
;; Retrieve the current LogFileOn value
(setq currLogFileOn (vla-get-LogFileOn (vla-get-OpenSave preferences)))
(alert (strcat "The current value for LogFileOn is " (if (= currLogFileOn :vlax-true) "True" "False")))
;; Change the value for LogFileOn
(vla-put-LogFileOn (vla-get-OpenSave preferences) (if (= currLogFileOn :vlax-true) :vlax-false :vlax-true))
(alert (strcat "The new value for LogFileOn is " (if (= (vla-get-LogFileOn (vla-get-OpenSave preferences)) :vlax-true) "True" "False")))
;; Reset LogFileOn to its original value
(vla-put-LogFileOn (vla-get-OpenSave preferences) currLogFileOn)
(alert (strcat "The LogFileOn value is reset to " (if (= (vla-get-LogFileOn (vla-get-OpenSave preferences)) :vlax-true) "True" "False")))
GMT+8, 2026-10-26 19:07
