LineweightDisplay 属性 (ActiveX)
指定是否在绘图的模型空间中显示线宽。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。True AutoCAD 再生时间随着线宽的增加而增加,线宽由多个像素表示。将此特性设置为在使用大线宽时 AutoCAD 性能降低的情况。False 例子VBA: Sub Example_LineweightDisplay()
' This example reads and modifies the preference value that controls
' whether symbol names may include extended character sets, or more
' than 31 characters.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadDatabasePreferences
' Get the user preferences object
Set ACADPref = ThisDrawing.preferences
originalValue = ACADPref.LineWeightDisplay
MsgBox "The LineweightDisplay preference is set to: " & originalValue
' Modify the LineweightDisplay preference by toggling the value
ACADPref.LineWeightDisplay = Not (ACADPref.LineWeightDisplay)
newValue = ACADPref.LineWeightDisplay
MsgBox "The LineweightDisplay preference has been set to: " & newValue
' this preference in effect
ACADPref.LineWeightDisplay = originalValue
MsgBox "The LineweightDisplay preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_LineweightDisplay()
;; This example reads and modifies the preference value that controls
;; the display of lineweights in the drawing window.
;; When finished, this example resets the preference value back to
;; its original value.
(setq preferences (vla-get-Preferences doc))
(setq originalValue (vla-get-LineWeightDisplay preferences))
(alert (strcat "The LineweightDisplay preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the LineweightDisplay preference by toggling the value
(vla-put-LineWeightDisplay preferences (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(setq newValue (vla-get-LineWeightDisplay preferences))
(alert (strcat "The LineweightDisplay preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
;; this preference in effect
(vla-put-LineWeightDisplay preferences originalValue)
(alert (strcat "The LineweightDisplay preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-10-28 00:07
