LineSpacingFactor 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 663| 评论: 0|原作者: admin|来自: AutoCAD
指定 MText 对象的相对行距系数。
object.LineSpacingFactor
类型:GeoPositionMarker、MText
此属性应用于的对象。
只读:不
类型:双
对象的相对行距系数。输入一个介于 0.25 和 4(含 0.25 和 4)之间的值。MText
间距系数是一行文本的基线与下一行文本行的基线之间的垂直距离。间距系数设置为单行间距的倍数。
可以使用该属性将行距设置为“至少”指定距离或“完全”指定距离。LineSpacingStyle
Sub Example_LineSpacingFactor()
    ' This example creates an MText object in model space
    ' and then finds the LineSpacingFactor for the object.
    Dim MTextObj As AcadMText
    Dim corner(0 To 2) As Double
    Dim width As Double
    Dim text As String
    corner(0) = 0#: corner(1) = 10#: corner(2) = 0#
    width = 10
    text = "This is the text String for the mtext Object"
    ' Creates the MText Object
    Set MTextObj = ThisDrawing.ModelSpace.AddMText(corner, width, text)
    ZoomAll
    ' Find the current LineSpacingFactor
    Dim currFactor As Double
    currFactor = MTextObj.LineSpacingFactor
    MsgBox "The LineSpacingFactor for the MText object is: " & currFactor
    ' Change the LineSpacingFactor
    MTextObj.LineSpacingFactor = 4
    MsgBox "The LineSpacingFactor for the MText object is: " & MTextObj.LineSpacingFactor
    ' Reset the LineSpacingFactor
    MTextObj.LineSpacingFactor = currFactor
(defun c:Example_LineSpacingFactor()
    ;; This example creates an MText object in model space
    ;; and then finds the LineSpacingFactor for the object.
    (setq corner (vlax-3d-point 0 10 0)
          width 10
          text "This is the text String for the mtext Object")
    ;; Creates the MText Object
    (setq MTextObj (vla-AddMText modelSpace corner width text))
    (vla-ZoomAll acadObj)
    ;; Find the current LineSpacingFactor
    (setq currFactor (vla-get-LineSpacingFactor MTextObj))
    (alert (strcat "The LineSpacingFactor for the MText object is: " (rtos currFactor 2)))
    ;; Change the LineSpacingFactor
    (vla-put-LineSpacingFactor MTextObj 0.7)
    (alert (strcat "The LineSpacingFactor for the MText object is: " (rtos (vla-get-LineSpacingFactor MTextObj) 2)))
    ;; Reset the LineSpacingFactor
    (vla-put-LineSpacingFactor MTextObj currFactor)
GMT+8, 2026-10-27 21:23
