LeaderType 属性 (ActiveX)
指定引线的类型。 支持的平台:仅限 Windows 属性值只读:不 类型:枚举AcMLeaderType
言论没有其他评论。 例子VBA: Sub Example_LeaderLine()
Dim oML As AcadMLeader
Dim points(0 To 5) As Double
points(0) = 1: points(1) = 1: points(2) = 0
points(3) = 4: points(4) = 4: points(5) = 0
Dim i As Long
Set oML = ThisDrawing.ModelSpace.AddMLeader(points, i)
Dim r As Long
r = oML.AddLeader()
points(4) = 10
Call oML.AddLeaderLine(r, points)
MsgBox "LeaderCount = " & oML.LeaderCount
ZoomExtents
可视化 LISP: (vl-load-com)
(defun c:Example_LeaderLine()
(setq points (vlax-make-safearray vlax-vbDouble '(0 . 5)))
(vlax-safearray-fill points '(1 1 0
4 4 0
(setq i 0)
(setq oML (vla-AddMLeader modelSpace points i))
(setq r (vla-AddLeader oML))
(vlax-safearray-put-element points 4 10)
(vla-AddLeaderLine oML r points)
(alert (strcat "LeaderCount = " (itoa (vla-get-LeaderCount oML))))
(vla-ZoomExtents acadObj)
GMT+8, 2026-10-27 16:02
