Layouts 属性 (ActiveX)
获取文档的 Layouts 集合。 支持的平台:仅限 Windows 言论没有其他评论。 例子VBA: Sub Example_Layouts()
' This example will access the Layouts collection for the current drawing
' and list basic information about the Layouts in the drawing.
Dim Layouts As AcadLayouts, Layout As ACADLayout
Dim msg As String
' Get layouts collection from document object
Set Layouts = ThisDrawing.Layouts
msg = vbCrLf ' Start with a space
' Get the names of every layout in this drawing
For Each Layout In Layouts
msg = msg & Layout.name & vbCrLf
Next
' Display a list of available layouts
MsgBox "There are " & Layouts.count & " layouts in " & _
ThisDrawing.WindowTitle & ":" & msg
可视化 LISP: (vl-load-com)
(defun c:Example_Layouts()
;; This example will access the Layouts collection for the current drawing
;; and list basic information about the Layouts in the drawing.
;; Get layouts collection from document object
(setq Layouts (vla-get-Layouts doc))
(setq msg "") ;; Start with a space
;; Get the names of every layout in this drawing
(vlax-for Layout Layouts
(setq msg (strcat msg (vla-get-Name Layout) "\n"))
;; Display a list of available layouts
(alert (strcat "There are " (itoa (vla-get-Count Layouts)) " layouts in "
(vla-get-WindowTitle doc) ":\n" msg))
GMT+8, 2026-10-28 01:37
