LayoutDisplayPaper 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 848| 评论: 0|原作者: admin|来自: AutoCAD
在布局中切换纸张背景的显示。
object.LayoutDisplayPaper
类型:首选项显示
此属性应用于的对象。
只读:
类型:布尔
  • True:纸张背景显示在布局中。
  • False:布局中不显示纸张背景。
此属性的初始值为 。True
Sub Example_LayoutDisplayPaper()
    ' This example reads and modifies the preference value that controls
    ' the display of the paper background in layouts. When finished, this example
    ' resets the preference value back to its original value.
    Dim ACADPref As AcadPreferencesDisplay
    ' Get the display preferences object
    Set ACADPref = ThisDrawing.Application.preferences.DISPLAY
    ' Switch to paper space to view this change
    ThisDrawing.ActiveSpace = acPaperSpace
    originalValue = ACADPref.LayoutDisplayPaper
    MsgBox "The LayoutDisplayPaper preference is set to: " & originalValue
    ' Modify the LayoutDisplayPaper preference by toggling the value
    ACADPref.LayoutDisplayPaper = Not (originalValue)
    newValue = ACADPref.LayoutDisplayPaper
    MsgBox "The LayoutDisplayPaper preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.LayoutDisplayPaper = originalValue
    MsgBox "The LayoutDisplayPaper preference was reset back to: " & originalValue
(defun c:Example_LayoutDisplayPaper()
    ;; This example reads and modifies the preference value that controls
    ;; the display of the paper background in layouts. When finished, this example
    ;; resets the preference value back to its original value.
    ;; Switch to paper space to view this change
    (vla-put-ActiveSpace doc acPaperSpace)
    (setq originalValue (vla-get-LayoutDisplayPaper (vla-get-Display preferences)))
    (alert (strcat "The LayoutDisplayPaper preference is set to: " (if (= originalValue :vlax-true) "True"  "False")))
    ;; Modify the LayoutDisplayPaper preference by toggling the value
    (vla-put-LayoutDisplayPaper (vla-get-Display preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-LayoutDisplayPaper (vla-get-Display preferences)))
    (alert (strcat "The LayoutDisplayPaper preference has been set to: " (if (= newValue :vlax-true) "True"  "False")))
    ;;         this preference in effect
    (vla-put-LayoutDisplayPaper (vla-get-Display preferences) originalValue)
    (alert (strcat "The LayoutDisplayPaper preference was reset back to: " (if (= originalValue :vlax-true) "True"  "False")))
GMT+8, 2026-9-12 02:00
