Layout 属性 (ActiveX)
指定与模型空间、图纸空间或块对象关联的布局。 支持的平台:仅限 Windows 言论该对象包含模型空间、图纸空间或块对象的打印设置。Layout 未与给定块关联的命名绘图设置将存储为对象。PlotConfiguration 例子VBA: Sub Example_Layout()
' This example references the Layout object obtained from model space.
' We then display information from the Layout object.
Dim Layout As ACADLayout
' Attach to Layout object
Set Layout = ThisDrawing.ModelSpace.Layout
MsgBox "We now have access to the properties and methods of the model space Layout object!"
' Retrieve the name of the model space Layout
MsgBox "The name of the model space Layout is: " & Layout.name
可视化 LISP: (vl-load-com)
(defun c:Example_Layout()
;; This example references the Layout object obtained from model space.
;; We then display information from the Layout object.
;; Attach to Layout object
(setq Layout (vla-get-Layout (vla-get-ModelSpace doc)))
(alert "We now have access to the properties and methods of the model space Layout object!")
;; Retrieve the name of the model space Layout
(alert (strcat "The name of the model space Layout is: " (vla-get-Name Layout.name)))
GMT+8, 2026-10-27 14:27
