KeyboardPriority 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 1010| 评论: 0|原作者: admin|来自: AutoCAD
控制 AutoCAD 对坐标数据输入的响应方式。
object.KeyboardPriority
类型:PreferencesUser
此属性应用于的对象。
只读:不
类型:枚举acKeyboardPriority
  • acKeyboardRunningObjSnap:键入坐标时严格遵守对象捕捉。
  • acKeyboardEntry:键入坐标时严格遵守键盘输入值。
  • acKeyboardEntryExceptScripts:键入坐标时严格遵守键盘输入值。但是,当通过脚本输入坐标时,将遵循正在运行的对象捕捉。
此属性的初始值为 。acKeyboardEntryExceptScripts
注意:此属性的值存储在 OSNAPCOORD 系统变量中。
Sub Example_KeyboardPriority()
    ' KeyboardPriority. It then changes the value, and finally
    Dim currKeyboardPriority As Integer
    Dim constant As String
    Dim newConstant As String
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current KeyboardPriority value
    currKeyboardPriority = preferences.User.KeyboardPriority
    constant = Choose(currKeyboardPriority + 1, "acKeyboardRunningObjSnap", "acKeyboardEntry", "acKeyboardEntryExceptScripts")
    MsgBox "The current value for KeyboardPriority is " & constant, vbInformation, "KeyboardPriority Example"
    ' Change the value for KeyboardPriority
    newConstant = "acKeyboardEntry"
    preferences.User.KeyboardPriority = acKeyboardEntry
    MsgBox "The new value for KeyboardPriority is " & newConstant, vbInformation, "KeyboardPriority Example"
    ' Reset KeyboardPriority to its original value
    preferences.User.KeyboardPriority = currKeyboardPriority
    MsgBox "The KeyboardPriority value is reset to " & constant, vbInformation, "KeyboardPriority Example"
(defun c:Example_KeyboardPriority()
    ;; KeyboardPriority. It then changes the value, and finally
    ;; Retrieve the current KeyboardPriority value
    (setq currKeyboardPriority (vla-get-KeyboardPriority (vla-get-User preferences)))
    (setq constant (cond
                     ((= currKeyboardPriority 0) "acKeyboardRunningObjSnap")
                     ((= currKeyboardPriority 1) "acKeyboardEntry")
                     ((= currKeyboardPriority 2) "acKeyboardEntryExceptScripts")))
    (alert (strcat "The current value for KeyboardPriority is " constant))
    ;; Change the value for KeyboardPriority
    (setq newConstant "acKeyboardEntry")
    (vla-put-KeyboardPriority (vla-get-User preferences) acKeyboardEntry)
    (alert (strcat "The new value for KeyboardPriority is " newConstant))
    ;; Reset KeyboardPriority to its original value
    (vla-put-KeyboardPriority (vla-get-User preferences) currKeyboardPriority)
    (alert (strcat "The KeyboardPriority value is reset to " constant))
GMT+8, 2026-11-11 04:57
