IsPeriodic 属性 (ActiveX)
确定给定样条是否为周期性样条曲线。 支持的平台:仅限 Windows 属性值只读:是的 类型:布尔
言论没有其他评论。 例子VBA: Sub Example_IsPeriodic()
' This example creates a Spline object in model space and
' determines if the Spline is periodic
Dim splineObj As AcadSpline
Dim startTan(0 To 2) As Double, endTan(0 To 2) As Double
Dim fitPoints(0 To 8) As Double
Dim UserMessage As String
' Define the Spline object
startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
fitPoints(0) = 0: fitPoints(1) = 0: fitPoints(2) = 0: fitPoints(3) = 5
fitPoints(4) = 5: fitPoints(5) = 0: fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
' Create new Spline object
Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
' Display whether or not new Spline is periodic
UserMessage = IIf(splineObj.IsPeriodic, "is periodic", "is not periodic")
MsgBox "The new Spline " & UserMessage
可视化 LISP: (vl-load-com)
(defun c:Example_IsPeriodic()
;; This example creates a Spline object in model space and
;; determines if the Spline is periodic
;; Define the Spline object
(setq startTan (vlax-3d-point 0.5 0.5 0)
endTan (vlax-3d-point 0.5 0.5 0)
fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
(vlax-safearray-fill fitPoints '(0 0 0
5 5 0
10 0 0
;; Create new Spline object
(setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
(vla-ZoomAll acadObj)
;; Display whether or not new Spline is periodic
(setq UserMessage (if (= (vla-get-IsPeriodic splineObj) :vlax-true) "is periodic" "is not periodic"))
(alert (strcat "The new Spline " UserMessage))
GMT+8, 2026-10-29 02:45
