ImageVisibility 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 667| 评论: 0|原作者: admin|来自: AutoCAD
指定图像可见性是打开还是关闭。
object.ImageVisibility
类型:GeomapImage、RasterImage、Wipeout
此属性应用于的对象。
只读:不
类型:布尔
  • True:图像可见。
  • False:图像处于隐藏状态。
在当前绘图会话中不需要图像可见性时,可以通过关闭图像可见性来提高重绘速度。不显示或绘制隐藏的图像;仅显示绘图边界。您可以选择隐藏图像,而不考虑当前视口坐标系,或者特别是当图像与当前视口坐标系不正交(对齐)时。
Sub Example_ImageVisibility()
    ' This example inserts a raster image and finds the current status
    ' of ImageVisibility for the image. It then changes the ImageVisibility
    ' status of the image.
    ' This example uses the "2d Projected Polylines.jpg" found in the Sample
    ' directory. If you do not have the image, or if it is located
    ' in a different directory, insert a valid path and name for the
    ' imageName variable below.
    Dim scalefactor As Double
    Dim rotAngleInDegree As Double, rotAngle As Double
    Dim imageName As String
    Dim raster As AcadRasterImage
    imageName = "C:\AutoCAD\sample\2d Projected Polylines.jpg"
    insertionPoint(0) = 2#: insertionPoint(1) = 2#: insertionPoint(2) = 0#
    scalefactor = 1#
    rotAngleInDegree = 0#
    rotAngle = rotAngleInDegree * 3.141592 / 180#
    On Error Resume Next
    ' Creates a raster image in model space
    Set raster = ThisDrawing.ModelSpace.AddRaster(imageName, insertionPoint, scalefactor, rotAngle)
    If Err.Description = "File error" Then
        MsgBox imageName & " could not be found."
        Exit Sub
    End If
    ' Find the current ImageVisibility
    ThisDrawing.Regen True
    MsgBox "The ImageVisibility is currently set to: " & raster.ImageVisibility, vbInformation
    ' Change the ImageVisibility
    If (raster.ImageVisibility) Then
        raster.ImageVisibility = False
    Else
        raster.ImageVisibility = True
    End If
    MsgBox "The ImageVisibility is now set to: " & raster.ImageVisibility, vbInformation
(defun c:Example_ImageVisibility()
    ;; This example inserts a raster image and finds the current status
    ;; of ImageVisibility for the image. It then changes the ImageVisibility
    ;; status of the image.
    ;; This example uses the "2d Projected Polylines.jpg" found in the Sample
    ;; directory. If you do not have the image, or if it is located
    ;; in a different directory, insert a valid path and name for the
    ;; imageName variable below.
    (setq insertionPoint (vlax-3d-point 2 2 0)
          imageName ".\\Sample\\VBA\\2d Projected Polylines.jpg"
          scalefactor 1
          rotAngle (/ (* 0 3.141592 180)))
    ;; Creates a raster image in model space
    (if (/= (findfile imageName) nil)
        (progn
            (setq raster (vla-AddRaster modelSpace (findfile imageName) insertionPoint scalefactor rotAngle))
	           ;; Find the current ImageVisibility
	           (vla-Regen doc :vlax-true)
	           (alert (strcat "The ImageVisibility is currently set to: " (if (= (vla-get-ImageVisibility raster) :vlax-true) "True" "False")))
	           ;; Change the ImageVisibility
	               (vla-put-ImageVisibility raster :vlax-false)
	               (vla-put-ImageVisibility raster :vlax-true)
	           (alert (strcat "The ImageVisibility is now set to: " (if (= (vla-get-ImageVisibility raster) :vlax-true) "True" "False")))
        (alert (strcat imageName " could not be found."))
GMT+8, 2026-10-27 21:25
