ImageHeight 属性 (ActiveX)
指定光栅图像的高度。 支持的平台:仅限 Windows 属性值只读:不 类型:双 光栅图像的高度。 言论此属性与属性类似。该属性指定图像的高度(以像素为单位)。此属性指定图像的高度(以当前单位为单位)。HeightHeight 例子VBA: Sub Example_ImageHeight()
' This example adds a raster image in model space and then finds
' the height and width of the image.
' This example uses the "2d Projected Polylines.jpg" found in the Sample
' directory. If you do not have this image, or if it is located
' in a different directory, insert a valid path and file name
' for the imageName variable below.
Dim scalefactor As Double
Dim rotationAngle As Double
Dim imageName As String
Dim rasterObj As AcadRasterImage
imageName = "C:/AutoCAD/sample/2d Projected Polylines.jpg"
insertionPoint(0) = 5#: insertionPoint(1) = 5#: insertionPoint(2) = 0#
scalefactor = 1#
rotationAngle = 0
' Creates a raster image in model space
Set rasterObj = ThisDrawing.ModelSpace.AddRaster(imageName, insertionPoint, scalefactor, rotationAngle)
' Find the height and width of the raster image
Dim height As Variant
Dim width As Variant
height = rasterObj.ImageHeight
width = rasterObj.ImageWidth
MsgBox "Raster image: " & rasterObj.ImageFile & vbCrLf & _
"ImageHeight: " & Str(height) & vbCrLf & _
"ImageWidth: " & Str(width)
可视化 LISP: (vl-load-com)
(defun c:Example_ImageHeight()
;; This example adds a raster image in model space and then finds
;; the height and width of the image.
;; This example uses the "2d Projected Polylines.jpg" found in the Sample
;; directory. If you do not have this image, or if it is located
;; in a different directory, insert a valid path and file name
;; for the imageName variable below.
(setq insertionPoint (vlax-3d-point 5 5 0)
imageName ".\\Sample\\VBA\\2d Projected Polylines.jpg"
scalefactor 1
rotationAngle 0)
;; Creates a raster image in model space
(if (/= (findfile imageName) nil)
(progn
(setq rasterObj (vla-AddRaster modelSpace (findfile imageName) insertionPoint scalefactor rotationAngle))
;; Find the height and width of the raster image
(setq height (vla-get-ImageHeight rasterObj)
width (vla-get-ImageWidth rasterObj))
(alert (strcat "Raster image: " (vla-get-ImageFile rasterObj)
"\nImageHeight: " (rtos height 2)
"\nImageWidth: " (rtos width 2)))
(alert (strcat imageName " could not be found."))
GMT+8, 2026-10-28 23:46
