ImageFrameHighlight 属性 (ActiveX)
控制选择期间光栅图像的显示。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。True 注意:此属性的此值存储在 IMAGEHLT 系统变量中。
例子VBA: Sub Example_ImageFrameHighlight()
' This example reads and modifies the preference value that controls
' the display of raster images during selection. When finished, this example
' resets the preference value back to its original value.
Dim ACADPref As AcadPreferencesDisplay
' Get the display preferences object
Set ACADPref = ThisDrawing.Application.preferences.DISPLAY
originalValue = ACADPref.ImageFrameHighlight
MsgBox "The ImageFrameHighlight preference is set to: " & originalValue
' Modify the ImageFrameHighlight preference by toggling the value
ACADPref.ImageFrameHighlight = Not (originalValue)
newValue = ACADPref.ImageFrameHighlight
MsgBox "The ImageFrameHighlight preference has been set to: " & newValue
' this preference in effect
ACADPref.ImageFrameHighlight = originalValue
MsgBox "The ImageFrameHighlight preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_ImageFrameHighlight()
;; This example reads and modifies the preference value that controls
;; the display of raster images during selection. When finished, this example
;; resets the preference value back to its original value.
(setq originalValue (vla-get-ImageFrameHighlight (vla-get-Display preferences)))
(alert (strcat "The ImageFrameHighlight preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the ImageFrameHighlight preference by toggling the value
(vla-put-ImageFrameHighlight (vla-get-Display preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(setq newValue (vla-get-ImageFrameHighlight (vla-get-Display preferences)))
(alert (strcat "The ImageFrameHighlight preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
;; this preference in effect
(vla-put-ImageFrameHighlight (vla-get-Display preferences) originalValue)
(alert (strcat "The ImageFrameHighlight preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-10-29 06:17
