HyperlinkBase 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 985| 评论: 0|原作者: admin|来自: AutoCAD
指定用于图形中插入的所有相对链接的基址。
object.HyperlinkBase
类型:SummaryInfo
此属性应用于的对象。
只读:不
类型:字符串
图形的属性。HyperlinkBase
您可以指定 Internet 位置或网络驱动器上文件夹的路径。
Sub Example_HyperlinkBase()
    ' This example shows how to access drawing properties
    ' Add and display standard properties
    ThisDrawing.SummaryInfo.Author = "John Doe"
    ThisDrawing.SummaryInfo.Comments = "Includes all ten levels of Building Five"
    ThisDrawing.SummaryInfo.HyperlinkBase = "https://www.autodesk.com"
    ThisDrawing.SummaryInfo.Keywords = "Building Complex"
    ThisDrawing.SummaryInfo.LastSavedBy = "JD"
    ThisDrawing.SummaryInfo.RevisionNumber = "4"
    ThisDrawing.SummaryInfo.Subject = "Plan for Building Five"
    ThisDrawing.SummaryInfo.Title = "Building Five"
    Author = ThisDrawing.SummaryInfo.Author
    Comments = ThisDrawing.SummaryInfo.Comments
    HLB = ThisDrawing.SummaryInfo.HyperlinkBase
    KW = ThisDrawing.SummaryInfo.Keywords
    LSB = ThisDrawing.SummaryInfo.LastSavedBy
    RN = ThisDrawing.SummaryInfo.RevisionNumber
    Subject = ThisDrawing.SummaryInfo.Subject
    Title = ThisDrawing.SummaryInfo.Title
    MsgBox "The standard drawing properties are " & vbCrLf & _
            "Author = " & Author & vbCrLf & _
            "Comments = " & Comments & vbCrLf & _
            "HyperlinkBase = " & HLB & vbCrLf & _
            "Keywords = " & KW & vbCrLf & _
            "LastSavedBy = " & LSB & vbCrLf & _
            "RevisionNumber = " & RN & vbCrLf & _
            "Subject = " & Subject & vbCrLf & _
            "Title = " & Title & vbCrLf
    ' Add and display custom properties
    Dim Key0 As String
    Dim Value0 As String
    Dim Key1 As String
    Dim Value1 As String
    Dim CustomPropertyBranch As String
    Dim PropertyBranchValue As String
    Dim CustomPropertyZone As String
    Dim PropertyZoneValue As String
    CustomPropertyBranch = "Branch"
    PropertyBranchValue = "Main"
    CustomPropertyZone = "Zone"
    PropertyZoneValue = "Industrial"
    ' Add custom properties
    If (ThisDrawing.SummaryInfo.NumCustomInfo >= 1) Then
        ThisDrawing.SummaryInfo.SetCustomByIndex 0, CustomPropertyBranch, PropertyBranchValue
    Else
        ThisDrawing.SummaryInfo.AddCustomInfo CustomPropertyBranch, PropertyBranchValue
    End If
    If (ThisDrawing.SummaryInfo.NumCustomInfo >= 2) Then
         ThisDrawing.SummaryInfo.SetCustomByKey CustomPropertyBranch, "Satellite"
    Else
         ThisDrawing.SummaryInfo.AddCustomInfo CustomPropertyZone, PropertyZoneValue
    End If
    'Get custom properties
    ThisDrawing.SummaryInfo.GetCustomByIndex 0, Key0, Value0
    Key1 = CustomPropertyZone
    ThisDrawing.SummaryInfo.GetCustomByKey Key1, Value1
    MsgBox "The custom drawing properties are " & vbCrLf & _
            "First property name = " & Key0 & vbCrLf & _
            "First property value = " & Value0 & vbCrLf & _
            "Second property name = " & Key1 & vbCrLf & _
            "Second property value = " & Value1 & vbCrLf
(defun c:Example_HyperlinkBase()
    ;; This example shows how to access drawing properties
    (setq summaryInfo (vla-get-SummaryInfo doc))
    ;; Add and display standard properties
    (vla-put-Author summaryInfo "John Doe")
    (vla-put-Comments summaryInfo "Includes all ten levels of Building Five")
    (vla-put-HyperlinkBase summaryInfo "https://www.autodesk.com")
    (vla-put-Keywords summaryInfo "Building Complex")
    (vla-put-LastSavedBy summaryInfo "JD")
    (vla-put-RevisionNumber summaryInfo "4")
    (vla-put-Subject summaryInfo "Plan for Building Five")
    (vla-put-Title summaryInfo "Building Five")
    (setq author (vla-get-Author summaryInfo))
    (setq comments (vla-get-Comments summaryInfo))
    (setq HLB (vla-get-HyperlinkBase summaryInfo))
    (setq KW (vla-get-Keywords summaryInfo))
    (setq LSB (vla-get-LastSavedBy summaryInfo))
    (setq RN (vla-get-RevisionNumber summaryInfo))
    (setq subject (vla-get-Subject summaryInfo))
    (setq Title (vla-get-Title summaryInfo))
    (alert (strcat "The standard drawing properties are "
                   "\nAuthor = " author
                   "\nComments = " comments
                   "\nHyperlinkBase = " HLB
                   "\nKeywords = " KW
                   "\nLastSavedBy = " LSB
                   "\nRevisionNumber = " RN
                   "\nSubject = " Subject
                   "\nTitle = " Title
    ;; Add and display custom properties
    (setq CustomPropertyBranch "Branch")
    (setq PropertyBranchValue "Main")
    (setq CustomPropertyZone "Zone")
    (setq PropertyZoneValue "Industrial")
    ;; Add custom properties
    (if (>= (vla-NumCustomInfo summaryInfo) 1)
        (vla-SetCustomByIndex summaryInfo 0 CustomPropertyBranch PropertyBranchValue)
        (vla-AddCustomInfo summaryInfo CustomPropertyBranch PropertyBranchValue)
    (if (>= (vla-NumCustomInfo summaryInfo) 2)
        (vla-SetCustomByKey summaryInfo CustomPropertyBranch "Satellite")
        (vla-AddCustomInfo summaryInfo CustomPropertyZone PropertyZoneValue)
    ;; Get custom properties
    (vla-GetCustomByIndex summaryInfo 0 'Key0 'Value0)
    (setq Key1 CustomPropertyZone)
    (vla-GetCustomByKey summaryInfo Key1 'Value1)
    (alert (strcat "The custom drawing properties are "
                   "\nFirst property name = " Key0
                   "\nFirst property value = " Value0
                   "\nSecond property name = " Key1
                   "\nSecond property value = " Value1
GMT+8, 2026-10-29 02:45
