HWND 属性 (ActiveX)
获取窗口框架的窗口控点。 支持的平台:仅限 Windows 属性值只读:是的 类型:Long_PTR 窗框的把手。 言论没有其他评论。 例子VBA: Sub Example_HWND()
' This example returns the handle (Hwnd) of a document window. The handle can be
' used with WindowsAPI calls, or with ActiveX components that require a handle
' to a window.
' If there are no open documents, then exit
If Documents.Count = 0 Then
MsgBox "There are no open documents!"
Exit Sub
End If
MsgBox "The HWND of the active document is: " & ActiveDocument.HWND
可视化 LISP: (vl-load-com)
(defun c:Example_HWND()
;; This example returns the handle (Hwnd) of a document window. The handle can be
;; used with WindowsAPI calls, or with ActiveX components that require a handle
;; to a window.
(alert (strcat "The HWND of the active document is: " (itoa (vla-get-HWND doc))))
GMT+8, 2026-10-28 08:16
