HorizontalTextPosition 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 815| 评论: 0|原作者: admin|来自: AutoCAD
指定尺寸文本的水平对齐方式。
object.HorizontalTextPosition
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimRotated
此属性应用于的对象。
只读:不
类型:枚举acDimHorizontalJustification
  • acHorzCentered:文本沿扩展线之间的尺寸线居中。
  • acFirstExtensionLine:文本位于第一行扩展线旁边。
  • acSecondExtensionLine:文本位于第二个扩展行旁边。
  • acOverFirstExtension:文本位于上方,并与第一个扩展行对齐。
  • acOverSecondExtension:文本位于上方,并与第二条延长线对齐。
注意:此属性将覆盖给定维度的 DIMJUST 系统变量的值。
Sub Example_HorizontalTextPosition()
    ' This example creates an aligned dimension in model space
    ' and cycles the dimension text through different
    ' horizontal alignments
    Dim dimObj As AcadDimAligned
    Dim CurrentValue As String
    ' Define the dimension
    point2(0) = 9: point2(1) = 5: point2(2) = 0
    ' Read and display current text position
    Select Case dimObj.HorizontalTextPosition
        Case acHorzCentered:        CurrentValue = "centered"
        Case acFirstExtensionLine:  CurrentValue = "aligned to first extension line"
        Case acSecondExtensionLine: CurrentValue = "aligned to second extension line"
        Case acOverFirstExtension:  CurrentValue = "aligned over first extension line"
        Case acOverSecondExtension: CurrentValue = "aligned over second extension line"
    End Select
    MsgBox "The dimension is " & CurrentValue
    ' Force the alignment of the dimension text to the first extension line
    dimObj.HorizontalTextPosition = acFirstExtensionLine
    MsgBox "Dimension text is now aligned to the first extension line"
    ' Force the alignment of the dimension text to the second extension line
    dimObj.HorizontalTextPosition = acSecondExtensionLine
    MsgBox "Dimension text is now aligned to the second extension line"
(defun c:Example_HorizontalTextPosition()
    ;; This example creates an aligned dimension in model space
    ;; and cycles the dimension text through different
    ;; horizontal alignments
    ;; Define the dimension
          point2 (vlax-3d-point 9 5 0)
    (vla-ZoomAll acadObj)
    ;; Read and display current text position
    (cond
        ((= (vla-get-HorizontalTextPosition dimObj) acHorzCentered) (setq CurrentValue "centered"))
        ((= (vla-get-HorizontalTextPosition dimObj) acFirstExtensionLine) (setq CurrentValue "aligned to first extension line"))
        ((= (vla-get-HorizontalTextPosition dimObj) acSecondExtensionLine) (setq CurrentValue "aligned to second extension line"))
        ((= (vla-get-HorizontalTextPosition dimObj) acOverFirstExtension) (setq CurrentValue "aligned over first extension line"))
        ((= (vla-get-HorizontalTextPosition dimObj) acOverSecondExtension) (setq CurrentValue "aligned over second extension line"))
    (alert (strcat "The dimension is " CurrentValue))
    ;; Force the alignment of the dimension text to the first extension line
    (vla-put-HorizontalTextPosition dimObj acFirstExtensionLine)
    (alert "Dimension text is now aligned to the first extension line")
    ;; Force the alignment of the dimension text to the second extension line
    (vla-put-HorizontalTextPosition dimObj acSecondExtensionLine)
    (alert "Dimension text is now aligned to the second extension line")
GMT+8, 2026-10-28 00:00
