HistoryLines 属性 (ActiveX)
指定文本窗口中要保留在内存中的文本行数。 支持的平台:仅限 Windows 属性值只读:不 类型:整数 初始值为 400。 言论没有其他评论。 例子VBA: Sub Example_HistoryLines()
' HistoryLines. It then changes the value, and finally
Dim currHistoryLines As Integer
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current HistoryLines value
currHistoryLines = preferences.DISPLAY.HistoryLines
MsgBox "The current value for HistoryLines is " & preferences.DISPLAY.HistoryLines, vbInformation, "HistoryLines Example"
' Change the value for HistoryLines
preferences.DISPLAY.HistoryLines = 42
MsgBox "The new value for HistoryLines is " & preferences.DISPLAY.HistoryLines, vbInformation, "HistoryLines Example"
' Reset HistoryLines to its original value
preferences.DISPLAY.HistoryLines = currHistoryLines
MsgBox "The HistoryLines value is reset to " & preferences.DISPLAY.HistoryLines, vbInformation, "HistoryLines Example"
可视化 LISP: (vl-load-com)
(defun c:Example_HistoryLines()
;; HistoryLines. It then changes the value, and finally
;; Retrieve the current HistoryLines value
(setq currHistoryLines (vla-get-HistoryLines (vla-get-Display preferences)))
(alert (strcat "The current value for HistoryLines is " (itoa currHistoryLines)))
;; Change the value for HistoryLines
(vla-put-HistoryLines (vla-get-Display preferences) 42)
(alert (strcat "The new value for HistoryLines is " (itoa (vla-get-HistoryLines (vla-get-Display preferences)))))
;; Reset HistoryLines to its original value
(vla-put-HistoryLines (vla-get-Display preferences) currHistoryLines)
(alert (strcat "The HistoryLines value is reset to " (itoa (vla-get-HistoryLines (vla-get-Display preferences)))))
GMT+8, 2026-11-11 04:56
