HelpFilePath 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 1010| 评论: 0|原作者: admin|来自: AutoCAD
指定 AutoCAD 帮助文件的位置。
object.HelpFilePath
类型:PreferencesFiles
此属性应用于的对象。
只读:不
类型:字符串
AutoCAD 帮助文件的位置。
此特性指定 AutoCAD 帮助文件的驱动器、路径和文件名。
Sub Example_HelpFilePath()
    ' HelpFilePath. It then changes the value, and finally
    Dim currHelpFilePath As String
    Dim newHelpFilePath As String
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current HelpFilePath value
    currHelpFilePath = preferences.Files.HelpFilePath
    MsgBox "The current value for HelpFilePath is " & currHelpFilePath, vbInformation, "HelpFilePath Example"
    ' Change the value for HelpFilePath
    newHelpFilePath = "C:/AutoCAD/Help"
    preferences.Files.HelpFilePath = newHelpFilePath
    MsgBox "The new value for HelpFilePath is " & newHelpFilePath, vbInformation, "HelpFilePath Example"
    ' Reset HelpFilePath to its original value
    preferences.Files.HelpFilePath = currHelpFilePath
    MsgBox "The HelpFilePath value is reset to " & currHelpFilePath, vbInformation, "HelpFilePath Example"
(defun c:Example_HelpFilePath()
    ;; HelpFilePath. It then changes the value, and finally
    ;; Retrieve the current HelpFilePath value
    (setq currHelpFilePath (vla-get-HelpFilePath (vla-get-Files preferences)))
    (alert (strcat "The current value for HelpFilePath is " currHelpFilePath))
    ;; Change the value for HelpFilePath
    (setq newHelpFilePath "C:/AutoCAD/Help")
    (vla-put-HelpFilePath (vla-get-Files preferences) newHelpFilePath)
    (alert (strcat "The new value for HelpFilePath is " newHelpFilePath))
    ;; Reset HelpFilePath to its original value
    (vla-put-HelpFilePath (vla-get-Files preferences) currHelpFilePath)
    (alert (strcat "The HelpFilePath value is reset to " currHelpFilePath))
GMT+8, 2026-10-27 13:28
