GripSize 属性 (ActiveX)
指定夹点的大小。 支持的平台:仅限 Windows 属性值只读:不 类型:朗特 为显示夹点而绘制的框的大小,以像素为单位。此属性的实际范围是 1 到 20,但从 1 到 255 的任何值都是有效的。 言论此属性的初始值为 3。 注意:此属性的值存储在 GRIPSIZE 系统变量中。
例子VBA: Sub Example_GripSize()
' This example reads and modifies the preference value that controls
' the size of grips. When finished, this example resets the
' preference value back to its original value.
Dim ACADPref As AcadPreferencesSelection
' Get the selection preferences object
Set ACADPref = ThisDrawing.Application.preferences.Selection
originalValue = ACADPref.GripSize
MsgBox "The GripSize preference is set to: " & originalValue
' Modify the GripSize preference by setting it to 5
ACADPref.GripSize = 5
newValue = ACADPref.GripSize
MsgBox "The GripSize preference has been set to: " & newValue
' this preference in effect
ACADPref.GripSize = originalValue
MsgBox "The GripSize preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_GripSize()
;; This example reads and modifies the preference value that controls
;; the size of grips. When finished, this example resets the
;; preference value back to its original value.
;; Get the selection preferences object
(setq ACADPref (vla-get-Selection (vla-get-preferences acadObj)))
(setq originalValue (vla-get-GripSize ACADPref))
(alert (strcat "The GripSize preference is set to: " (itoa originalValue)))
;; Modify the GripSize preference by setting it to 7
(vla-put-GripSize ACADPref 7)
(setq newValue (vla-get-GripSize ACADPref))
(alert (strcat "The GripSize preference has been set to: " (itoa newValue)))
;; this preference in effect
(vla-put-GripSize ACADPref originalValue)
(alert (strcat "The GripSize preference was reset back to: " (itoa originalValue)))
GMT+8, 2026-10-28 01:28
