GripColorUnselected 属性 (ActiveX)
指定未选定夹点的颜色。 支持的平台:仅限 Windows 属性值只读:不 类型:枚举acColor 控制选定的夹具(绘制为框轮廓)。有效范围为 1 到 255,或此处列出的常量之一:
言论此属性的初始值为 150。 注意:此属性的值存储在 GRIPCOLOR 系统变量中。
例子VBA: Sub Example_GripColorUnselected()
' This example reads and modifies the preference value that controls
' the color of unselected grips.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesSelection
' Get the selection preferences object
Set ACADPref = ThisDrawing.Application.preferences.Selection
originalValue = ACADPref.GripColorUnselected
MsgBox "The GripColorUnselected preference is set to: " & originalValue
' Modify the GripColorUnselected preference by setting it to green
ACADPref.GripColorUnselected = acGreen
newValue = ACADPref.GripColorUnselected
MsgBox "The GripColorUnselected preference has been set to: " & newValue
' this preference in effect
ACADPref.GripColorUnselected = originalValue
MsgBox "The GripColorUnselected preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_GripColorUnselected()
;; This example reads and modifies the preference value that controls
;; the color of unselected grips.
;; When finished, this example resets the preference value back to
;; its original value.
;; Get the selection preferences object
(setq ACADPref (vla-get-Selection (vla-get-preferences acadObj)))
(setq originalValue (vla-get-GripColorUnselected ACADPref))
(alert (strcat "The GripColorUnselected preference is set to: " (itoa originalValue)))
;; Modify the GripColorUnselected preference by setting it to green
(vla-put-GripColorUnselected ACADPref acGreen)
(setq newValue (vla-get-GripColorUnselected ACADPref))
(alert (strcat "The GripColorUnselected preference has been set to: " (itoa newValue)))
;; this preference in effect
(vla-put-GripColorUnselected ACADPref originalValue)
(alert (strcat "The GripColorUnselected preference was reset back to: " (itoa originalValue)))
GMT+8, 2026-10-28 01:11
