GraphicsWinModelBackgrndColor 属性 (ActiveX)
指定模型空间窗口的背景色。 支持的平台:仅限 Windows 属性值只读:不 类型:OLE_COLOR(常量)
言论此属性的默认颜色为 。vbBlack 例子VBA: Sub Example_GraphicsWinModelBackgrndColor()
' GraphicsWinModelBackgrndColor. It then changes the value, and finally
Dim currGraphicsWinModelBackgrndColor As OLE_COLOR
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current GraphicsWinModelBackgrndColor value
currGraphicsWinModelBackgrndColor = preferences.DISPLAY.GraphicsWinModelBackgrndColor
MsgBox "The current value for GraphicsWinModelBackgrndColor is " _
& preferences.DISPLAY.GraphicsWinModelBackgrndColor, vbInformation, "GraphicsWinModelBackgrndColor Example"
' Change the value for GraphicsWinModelBackgrndColor
preferences.DISPLAY.GraphicsWinModelBackgrndColor = 16
MsgBox "The new value for GraphicsWinModelBackgrndColor is " _
' Reset GraphicsWinModelBackgrndColor to its original value
preferences.DISPLAY.GraphicsWinModelBackgrndColor = currGraphicsWinModelBackgrndColor
MsgBox "The GraphicsWinModelBackgrndColor value is reset to " _
可视化 LISP: (vl-load-com)
(defun c:Example_GraphicsWinModelBackgrndColor()
;; GraphicsWinModelBackgrndColor. It then changes the value, and finally
;; Retrieve the current GraphicsWinModelBackgrndColor value
(setq currGraphicsWinModelBackgrndColor (vlax-variant-change-type (vla-get-GraphicsWinModelBackgrndColor (vla-get-Display preferences)) vlax-vbLong))
(alert (strcat "The current value for GraphicsWinModelBackgrndColor is " (itoa (vlax-variant-value currGraphicsWinModelBackgrndColor))))
;; Change the value for GraphicsWinModelBackgrndColor
(vla-put-GraphicsWinModelBackgrndColor ACADPref (vlax-make-variant 127 19))
(setq newValue (vlax-variant-change-type (vla-get-GraphicsWinModelBackgrndColor ACADPref) vlax-vbLong))
(alert (strcat "The new value for GraphicsWinModelBackgrndColor is " (itoa (vlax-variant-value newValue))))
;; Reset GraphicsWinModelBackgrndColor to its original value
(vla-put-GraphicsWinModelBackgrndColor ACADPref currGraphicsWinModelBackgrndColor)
(alert (strcat "The GraphicsWinModelBackgrndColor value is reset to " (itoa (vlax-variant-value currGraphicsWinModelBackgrndColor))))
GMT+8, 2026-10-26 19:51
