ForceLineInside 属性 (ActiveX)
指定是否在扩展线之间绘制尺寸线,即使文本放置在扩展线之外也是如此。 支持的平台:仅限 Windows 签名VBA: object.ForceLineInside
属性值只读:不 类型:布尔
言论此属性的初始值为 。False 对于半径和直径尺寸(当属性设置为 时),此属性在圆或圆弧内绘制尺寸线和箭头,并将文本和引线放在外部。TextInsideFalse 注意:此属性将覆盖给定维度的 DIMTOFL 系统变量的值。
例子VBA: Sub Example_ForceLineInside()
' This example creates an aligned dimension in model space
' and toggles dimension lines to be drawn between extension lines
Dim dimObj As AcadDimAligned
Dim CurrentValue As String
' Define the dimension
point2(0) = 5.5: point2(1) = 5: point2(2) = 0
' Read and display current line suppression information
CurrentValue = IIf(dimObj.ForceLineInside, "are", "are not")
MsgBox "Dimension lines " & CurrentValue & " forced between the extension lines"
' Force the display of dimension lines between the extension lines
dimObj.ForceLineInside = True
MsgBox "Dimension lines are forced between the extension lines"
' Do not force the display of dimension lines between the extension lines (default)
dimObj.ForceLineInside = False
MsgBox "Dimension lines are not forced between the extension lines"
可视化 LISP: (vl-load-com)
(defun c:Example_ForceLineInside()
;; This example creates an aligned dimension in model space
;; and toggles dimension lines to be drawn between extension lines
;; Define the dimension
point2 (vlax-3d-point 5.5 5 0)
(vla-ZoomAll acadObj)
;; Read and display current line suppression information
(setq CurrentValue (if (= (vla-get-ForceLineInside dimObj) :vlax-true) "are" "are not"))
(alert (strcat "Dimension lines " CurrentValue " forced between the extension lines"))
;; Force the display of dimension lines between the extension lines
(vla-put-ForceLineInside dimObj :vlax-true)
(alert "Dimension lines are forced between the extension lines")
;; Do not force the display of dimension lines between the extension lines (default)
(vla-put-ForceLineInside dimObj :vlax-false)
(alert "Dimension lines are not forced between the extension lines")
GMT+8, 2026-11-15 14:35
