FontFileMap 属性 (ActiveX)
指定文件的位置,用于定义 AutoCAD 应如何转换未找到的字体。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 字体映射文件的驱动器、路径和文件名。 言论没有其他评论。 例子VBA: Sub Example_FontFileMap()
' FontFileMap. It then changes the value, and finally
Dim currFontFileMap As String
Dim newFontFileMap As String
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current FontFileMap value
currFontFileMap = preferences.Files.FontFileMap
MsgBox "The current value for FontFileMap is " & currFontFileMap, vbInformation, "FontFileMap Example"
' Change the value for FontFileMap
newFontFileMap = "TestFontFileMap.fmp"
preferences.Files.FontFileMap = newFontFileMap
MsgBox "The new value for FontFileMap is " & newFontFileMap, vbInformation, "FontFileMap Example"
' Reset FontFileMap to its original value
preferences.Files.FontFileMap = currFontFileMap
MsgBox "The FontFileMap value is reset to " & currFontFileMap, vbInformation, "FontFileMap Example"
可视化 LISP: (vl-load-com)
(defun c:Example_FontFileMap()
;; FontFileMap. It then changes the value, and finally
;; Retrieve the current FontFileMap value
(setq currFontFileMap (vla-get-FontFileMap (vla-get-Files preferences)))
(alert (strcat "The current value for FontFileMap is " currFontFileMap))
;; Change the value for FontFileMap
;; The file being specified must exist or an error will be generated
(setq newFontFileMap "C:\\AutoCAD\\TestFontFileMap.fmp")
(vla-put-FontFileMap (vla-get-Files preferences) newFontFileMap)
(alert (strcat "The new value for FontFileMap is " newFontFileMap))
;; Reset FontFileMap to its original value
(vla-put-FontFileMap (vla-get-Files preferences) currFontFileMap)
(alert (strcat "The FontFileMap value is reset to " currFontFileMap))
GMT+8, 2026-10-26 18:24
