FontFile 属性 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 841| 评论: 0|原作者: admin|来自: AutoCAD
指定主字体文件名和路径。
object.FontFile
类型:TextStyle
此属性应用于的对象。
只读:不
类型:字符串
主字体文件路径。
若要指定亚洲语言字体文件,请使用该属性。BigFontFile
字体定义构成每个字符集的文本字符的形状。
注意:设置此属性后,必须调用该方法以查看对文本的更改。Regen
Sub Example_FontFile()
    ' the FontFile property. It then changes the value, and
    ' finally resets the value back to the original setting.
    Dim textStyle1 As AcadTextStyle
    Dim currFontFile As String
    Dim newFontFile As String
    Set textStyle1 = ThisDrawing.ActiveTextStyle
    ' Retrieve the current FontFile value
    currFontFile = textStyle1.fontFile
    MsgBox "The current value for FontFile is " & currFontFile, vbInformation, "FontFile Example"
    ' Change the value for FontFile
    newFontFile = "C:/AutoCAD/Fonts/italic.shx"
    textStyle1.fontFile = newFontFile
    MsgBox "The new value for FontFile is " & textStyle1.fontFile, vbInformation, "FontFile Example"
    ' Reset font file
    textStyle1.fontFile = currFontFile
    MsgBox "The value for FontFile has been reset to " & textStyle1.fontFile, vbInformation, "FontFile Example"
(defun c:Example_FontFile()
    ;; the FontFile property. It then changes the value, and
    ;; finally resets the value back to the original setting.
    (setq textStyle1 (vla-get-ActiveTextStyle doc))
    ;; Retrieve the current FontFile value
    (setq currFontFile (vla-get-FontFile textStyle1))
    (alert (strcat "The current value for FontFile is " currFontFile))
    ;; Change the value for FontFile
    (setq newFontFile (findfile "./Fonts/italic.shx"))
    (vla-put-FontFile textStyle1 newFontFile)
    (alert (strcat "The new value for FontFile is " (vla-get-FontFile textStyle1)))
    ;; Reset font file
    (if (= (findfile currFontFile) nil)
	(setq currFontFile (findfile (strcat (getenv "WinDir") "\\Fonts\\" currFontFile)))
    (vla-put-FontFile textStyle1 (findfile currFontFile))
    (alert (strcat "The value for FontFile has been reset to " (vla-get-FontFile textStyle1)))
GMT+8, 2026-10-27 13:29
