Files 属性 (ActiveX)
获取 PreferencesFiles 对象。 支持的平台:仅限 Windows 言论该对象保存存储在注册表中的“选项”对话框的“文件”选项卡中的所有选项。与图形一起存储的所有选项都可以在对象上找到。PreferencesFilesDatabasePreferences 例子VBA: Sub Example_Files()
' This example obtains a reference to the Files Preferences object
' from the Application Preferences object, and reads one of the File
' preferences
Dim ACADPref As AcadPreferencesFiles
' Obtain a reference to the Files Preferences object
Set ACADPref = ThisDrawing.Application.preferences.Files
MsgBox "We now have access to the properties and methods of the Files Preferences object!"
MsgBox "The File preference AutoSavePath is set to: " & ACADPref.AutoSavePath
可视化 LISP: (vl-load-com)
(defun c:Example_Files()
;; This example obtains a reference to the Files Preferences object
;; from the Application Preferences object, and reads one of the File
;; preferences
;; Obtain a reference to the Files Preferences object
(setq ACADPref (vla-get-Files preferences))
(alert "We now have access to the properties and methods of the Files Preferences object!")
(alert (strcat "The File preference AutoSavePath is set to: " (vla-get-AutoSavePath ACADPref)))
GMT+8, 2026-10-28 02:42
