ExtLine2Suppress 属性 (ActiveX)
指定第二条扩展线的隐含项。 支持的平台:仅限 Windows 签名VBA: object.ExtLine2Suppress
属性值只读:不 类型:布尔
言论此属性的初始值为 。False 注意:此属性将覆盖给定维度的 DIMSE2 系统变量的值。
例子VBA: Sub Example_ExtLine2Suppress()
' This example creates a Dim3PointAngular object in model space
' and suppresses the extension lines using the ExtLine1Suppress
' and ExtLine2Suppress properties
Dim DimPointAngularObj As AcadDim3PointAngular
Dim AngleVertex(0 To 2) As Double
Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double
Dim TextPoint(0 To 2) As Double
Dim Line1Suppressed As String, Line2Suppressed As String
' Define the new Dim3PointAngular object
AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0
FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0
SecondPoint(0) = 1: SecondPoint(1) = 4: SecondPoint(2) = 0
TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0
' Create the new Dim3PointAngular object in model space
Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint)
' Read and display current extension line suppression information
Line1Suppressed = IIf(DimPointAngularObj.ExtLine1Suppress, "is suppressed", "is not suppressed")
Line2Suppressed = IIf(DimPointAngularObj.ExtLine2Suppress, "is suppressed", "is not suppressed")
MsgBox "Line one of the extension " & Line1Suppressed & vbCrLf & _
"Line two of the extension " & Line2Suppressed
' Suppress line one of the extension
DimPointAngularObj.ExtLine1Suppress = True
MsgBox "Line one of the extension is now suppressed"
' Suppress line two of the extension
DimPointAngularObj.ExtLine2Suppress = True
MsgBox "Line two of the extension is now suppressed"
' Turn both extension lines back on
DimPointAngularObj.ExtLine1Suppress = False
DimPointAngularObj.ExtLine2Suppress = False
MsgBox "Both extension lines are now visible again"
可视化 LISP: (vl-load-com)
(defun c:Example_ExtLine2Suppress()
;; This example creates a Dim3PointAngular object in model space
;; and suppresses the extension lines using the ExtLine1Suppress
;; and ExtLine2Suppress properties
;; Define the new Dim3PointAngular object
(setq AngleVertex (vlax-3d-point 0 0 0)
FirstPoint (vlax-3d-point 2 2 0)
SecondPoint (vlax-3d-point 1 4 0)
TextPoint (vlax-3d-point 6 6 0))
;; Create the new Dim3PointAngular object in model space
(setq DimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
(vla-ZoomAll acadObj)
;; Read and display current extension line suppression information
(setq Line1Suppressed (if (= (vla-get-ExtLine1Suppress DimPointAngularObj) :vlax-true) "is suppressed" "is not suppressed"))
(setq Line2Suppressed (if (= (vla-get-ExtLine2Suppress DimPointAngularObj) :vlax-true) "is suppressed" "is not suppressed"))
(alert (strcat "Line one of the extension " Line1Suppressed "\n"
"Line two of the extension " Line2Suppressed))
;; Suppress line one of the extension
(vla-put-ExtLine1Suppress DimPointAngularObj :vlax-true)
(alert "Line one of the extension is now suppressed")
;; Suppress line two of the extension
(vla-put-ExtLine2Suppress DimPointAngularObj :vlax-true)
(alert "Line two of the extension is now suppressed")
;; Turn both extension lines back on
(vla-put-ExtLine1Suppress DimPointAngularObj :vlax-false)
(vla-put-ExtLine2Suppress DimPointAngularObj :vlax-false)
(alert "Both extension lines are now visible again")
GMT+8, 2026-10-28 19:36
