ExtLine2StartPoint 属性 (ActiveX)
指定第二条延伸线的起点。 支持的平台:仅限 Windows 属性值只读:不 类型:变体(双打的三元素阵列) 表示第二条延伸线起点的 3D 坐标。 言论and 属性等于方法中的 and 参数。延伸线最初是从 和 位置绘制到尺寸线的交点。AutoCAD 将尺寸标注线绘制为延长线之间的圆弧。ExtLine1StartPointExtLine2StartPointFirstEndPointSecondEndPointAddDimAngularFirstEndPointSecondEndPoint ![]() 例子VBA: Sub Example_ExtLine2StartPoint()
' This example creates an angular dimension. It then changes
' the location of the ExtLine2StartPoint.
Dim dimObj As AcadDimAngular
Dim angVert(0 To 2) As Double
Dim FirstPoint(0 To 2) As Double
Dim SecondPoint(0 To 2) As Double
Dim TextPoint(0 To 2) As Double
' Define the dimension
angVert(0) = 0#: angVert(1) = 5#: angVert(2) = 0#
FirstPoint(0) = 1#: FirstPoint(1) = 7#: FirstPoint(2) = 0#
SecondPoint(0) = 1#: SecondPoint(1) = 3#: SecondPoint(2) = 0#
TextPoint(0) = 3#: TextPoint(1) = 5#: TextPoint(2) = 0#
' Create the angular dimension in model space
Set dimObj = ThisDrawing.ModelSpace.AddDimAngular(angVert, FirstPoint, SecondPoint, TextPoint)
ZoomAll
MsgBox "The current value of ExtLine2StartPoint is " & dimObj.ExtLine2StartPoint(0) & ", " & dimObj.ExtLine2StartPoint(1) & ", " & dimObj.ExtLine2StartPoint(2), vbInformation, "ExtLine2StartPoint Example"
' Change the start point of the second extension line
FirstPoint(0) = 1: FirstPoint(1) = 4: FirstPoint(2) = 0
dimObj.ExtLine2StartPoint = FirstPoint
dimObj.Update
' Return the start point of the second extension line
' Note that the return value is a Variant
Dim retPnt As Variant
retPnt = dimObj.ExtLine2StartPoint
MsgBox "The new value of ExtLine2StartPoint is " & dimObj.ExtLine2StartPoint(0) & ", " & dimObj.ExtLine2StartPoint(1) & ", " & dimObj.ExtLine2StartPoint(2), vbInformation, "ExtLine2StartPoint Example"
可视化 LISP: (vl-load-com)
(defun c:Example_ExtLine2StartPoint()
;; This example creates an angular dimension. It then changes
;; the location of the ExtLine2StartPoint.
;; Define the dimension
(setq AngleVertex (vlax-3d-point 0 5 0)
FirstPoint (vlax-3d-point 1 7 0)
SecondPoint (vlax-3d-point 1 3 0)
TextPoint (vlax-3d-point 3 5 0))
;; Create the angular dimension in model space
(setq dimObj (vla-AddDimAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
(vla-ZoomAll acadObj)
(setq extLineStartPoint (vlax-safearray->list (vlax-variant-value (vla-get-ExtLine2StartPoint dimObj))))
(alert (strcat "The current value of ExtLine2StartPoint is " (rtos (nth 0 extLineStartPoint) 2) ", "
(rtos (nth 1 extLineStartPoint) 2) ", "
(rtos (nth 2 extLineStartPoint) 2)))
;; Change the start point of the second extension line
(setq FirstPoint (vlax-3d-point 1 4 0))
(vla-put-ExtLine2StartPoint dimObj FirstPoint)
(vla-Update dimObj)
;; Return the start point of the second extension line
;; Note that the return value is a Variant
(setq retPnt (vlax-safearray->list (vlax-variant-value (vla-get-ExtLine2StartPoint dimObj))))
(alert (strcat "The new value of ExtLine2StartPoint is " (rtos (nth 0 retPnt) 2) ", "
(rtos (nth 1 retPnt) 2) ", "
(rtos (nth 2 retPnt) 2)))
GMT+8, 2026-10-28 00:10
